Figured out flapper problem, REALLY need your help! *PICS*
Old Sep 7, 2003 | 03:52 PM
  #26
kpt4321's Avatar
Just have a decent shop chop the downpipe up, and weld a larger WG exit pipe on there. It should be at least 1.5 inch, you might as well go for like 2. It looks like you could barely fit a pencil into that damned pipe.
Old Sep 7, 2003 | 06:57 PM
  #27
Mighty's Avatar
If that was my car Id just cut that divider plate out. I figure theres a 90% chance that thatll fix your problems. Yeah sure external wastegates are better but they are more expensive and more work. You are doing this work yourself right? If you paid someone for that piece of crap you need to try to get them to fix it. Doesnt look like they know **** about turbos.
Old Sep 7, 2003 | 07:26 PM
  #28
LS_REX's Avatar
Default Re: (Mighty)
If you want a quick fix, do like Mighty says. Cut that ****** plate out and all of your problems will be solved. If you want to make more power, ditch the overpriced downpipe and get a real shop to make you one....
Rob
Old Sep 7, 2003 | 07:36 PM
  #29
Hoosier Daddy's Avatar
Default Re: (LS_REX)
I don't think the plate is in the way because it used to work =\
Old Sep 7, 2003 | 07:48 PM
  #30
Phaze2 Mike's Avatar
I think u should go down to RJs and ask them to compensate you for the loss, and if they do not, file with the better business buruea and tarnish their repuation for good. Or just throw a molotov cocktail in there after hours and let them know just what loss is.
Old Sep 7, 2003 | 07:56 PM
  #31
Mighty's Avatar
Its hard to tell but I thought the flapper might hit that divider plate. If you say it doesnt Id guess that little pipe is too small. Cutting out the divider would fix that too. What did it look like before?
Old Sep 7, 2003 | 08:13 PM
  #32
D3LSLO's Avatar
Default Re: (Nextekhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nextekhatch &raquo;</TD></TR><TR><TD CLASS="quote"> Or just throw a molotov cocktail in there after hours and let them know just what loss is. </TD></TR></TABLE>
Best idea ever, but please take pics/film it. FOR ME?.?.?.?
Old Sep 10, 2003 | 07:57 PM
  #33
PHiZ's Avatar
Default Re: (D3LSLO)
Update?
-PHiZ
Old Sep 11, 2003 | 07:48 AM
  #34
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Update?
-PHiZ</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=614349
Old Jul 21, 2004 | 05:36 AM
  #35
Charlie Moua's Avatar
Default Re: Figured out flapper problem, REALLY need your help! *PICS* (JalopySiR)
badd *** thread.
do you know who makes those in the picture?
Old Jul 21, 2004 | 06:01 AM
  #36
david@didrace.com's Avatar
Default Re: Figured out flapper problem, REALLY need your help! *PICS* (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">
1.) Remove the turbine housing and/or turbocharger from the vehicle. The turbine housing Wastegate arm will need to either be completely removed (Read Cut out with a torch) and the holes welded shut with nickel rod (using the pre-heat weld slow cool down method so the darn thing doesen't crack) or you could perhaps try http://www.muggyweld.com products, i haven't had any personal experience, but they have good claims and demonstrations.</TD></TR></TABLE>
Just a comment on that MuggyWeld stuff. Never had any experiences with it but it says on their site that the fillers melt at 300/650 degrees F. Either way that would never hold exhaust piping together (read: melt).
Old Jul 21, 2004 | 06:39 AM
  #37
BROOD's Avatar
Default Re: Figured out flapper problem, REALLY need your help! *PICS* (Charlie Moua)
Charlie Moua, that is a DSM tubular o2 housing....looks like a housing made by VRS. Usually around $300-$400 depending on SS or aluminized and 2.5" or 3"
There are quite a few other companies that make similar housings....
Victory Performance is another....I use this housing with some minor port matching and clean-up around the WG merge.
I'm not a big fan of the VRS housing because it is such a drastic re-entry into the exhaust route. The Victory housing is a better merge re-entry. One thing you will find with the DSM guys is that they do not fuss about WG re-entry like it is on H-T all the time. And this is not the only thing that is overly-internet engineered on H-T
Modified by BROOD at 7:49 AM 7/21/2004
Modified by BROOD at 7:50 AM 7/21/2004
Old Jul 21, 2004 | 07:06 AM
  #38
Default Re: Figured out flapper problem, REALLY need your help! *PICS* (BROOD)
Thanks a lot bro.
well I have an apexi kit
http://www.wabe.net/silum/turbo.html in the link you should fine some pictures of the downpipe flange.
I wanted to know if anyone here knew were i could get one made for my kit.
Old Jul 21, 2004 | 08:42 AM
  #39
https://honda-tech.com/zerothread?id=594006
http://www.camotuning.com/
<FONT COLOR="red"> <FONT SIZE="10"> Daym ! </FONT> </FONT>
.adam.
Aug 12, 2006 03:20 PM
Teg4e
Jun 26, 2006 04:00 PM
accordfreak
Dec 1, 2003 12:05 PM
Infinity_Racer
Sep 7, 2003 07:53 PM
93LSivic
Apr 16, 2002 10:09 AM
