FI with msd6a question
Old Dec 27, 2002 | 08:07 PM
_Endless_'s Avatar
Default FI with msd6a question
i have the msd6a in my turbocharge SiR. after the install, i noticed that the throttle response has noticeably improved but there SEEMS to be something wrong with my idling. i also noticed that the engine vibrates a bit while idling, i didn't notice this before i installed my msd6a. as far as i know, the engine is steady while idling and not vibrating a bit like now. is that normal with msd installation? what could be wrong?
Old Dec 27, 2002 | 08:57 PM
_Endless_'s Avatar
Default Re: FI with msd6a question (_Endless_)
bump...
Old Dec 28, 2002 | 03:50 AM
_Endless_'s Avatar
anyone??
Old Dec 28, 2002 | 07:23 AM
RAWB's Avatar
Double check your connections. I have the 6A on my car and it idles just like it did without it. Are you using the external coil?
Old Dec 29, 2002 | 04:36 PM
_Endless_'s Avatar
Default Re: FI with msd6a question (integracon)
nope, i'm using stock coil. everything is stock except the msd. one more funny thing is, whenever i shut the engine, it stalls for few milliseconds then turbo timer kicks in and rpm jumps to 1500rpm then back to normal idling while the turbo timer is counting down. this happens after i installed the msd6a. this is confusing and frustrating.
Old Dec 29, 2002 | 04:50 PM
MayhemSi's Avatar
My car does that same stutter with the greddy turbo timer and I don't have a msd box so perhaps that is unrelated.
Old Dec 29, 2002 | 07:55 PM
_Endless_'s Avatar
Default Re: FI with msd6a question (MayhemSi)
that's what making it confusing coz i don't know if it's the box or the timer.
Old Dec 29, 2002 | 08:15 PM
RAWB's Avatar
How's your timing?
Old Dec 30, 2002 | 12:44 PM
SIK IN DA HED's Avatar
New User
you might have a defective unit. those things usually crap out after awhile. i wouldnt recommend using the stock coil... get an external one. that might be your problem.
Old Jan 1, 2003 | 06:19 PM
_Endless_'s Avatar
timing is left at stock.
Ferio_EG9
Dec 19, 2008 05:13 AM
leira619
Oct 23, 2003 07:38 PM
leira619
Oct 23, 2003 04:12 PM
turb
Jan 14, 2003 12:37 AM
_Endless_
Dec 26, 2002 07:40 PM
