Feul Problem on boosted D, need help
Old Feb 13, 2006 | 05:37 PM
silverboost's Avatar
Default Feul Problem on boosted D, need help
Im running an fmu at 5psi until i have everythign ready for tuning but recntly ive been having problems. At high rpms my a/f gauge will show me that i drop to lean. I recently swapped an obd1 d16z6 in my 1998 hatch and im using ond2 injectors, but a p28 ecu. Can this be it? I went through 2 fmus and its the same problem with both.
Old Feb 13, 2006 | 05:50 PM
MikeD718's Avatar
Default Re: Feul Problem on boosted D, need help (silverboost)
what are you gonna tune it on? my friends turbo D would go lean at full throttle w/ the fmu.
Old Feb 13, 2006 | 05:54 PM
zeroice's Avatar
first, depending on the a/f guage and where you have it hooked up wont be entirely accurate... compared to a wideband which is very accurate.
Old Feb 13, 2006 | 06:08 PM
nonvtecD's Avatar
umm, if you're running an FMU I'm guessing you're looking at your narrowband gauge, which sucks. Get some real management and a real o2 sensor (wideband).
Old Feb 13, 2006 | 06:14 PM
King-Kong's Avatar
Im wondering if its just the gauge, because with regards to the injectors, you tend to run the injectors intended for that chassis unless you have run a resistor pack which will drop the impedience of the injctors. But with the FMU, I deffinatly recommend to keep off the boosting until you are ready to do it right. Also take into consideration that you are probably stock sized injectors and stock fuel pump. The FMU is what, probably 8 or 10:1 which makes static fuel pressure 40psi ish, 5 psi(+50lbs) 90psi of fuel, maybe your system cant hack it up top?
Just some suggestions to take into consideration.
Old Feb 13, 2006 | 06:17 PM
Default Re: (King-Kong)
i have a walbro 255 ppump and its a 12:1 fmu, and i will be gettin tuned with neptune in two months. I have a seperate sensor for the a/f guage hooked up in my downpipe, its right after my primary 02
Modified by silverboost at 7:36 PM 2/13/2006
Old Feb 14, 2006 | 01:54 PM
ok now i have another problem, my guage shows that im in lean all the time once my car warms up and doesnt move back and forth. Now sumtimes when i give it throtle the car wont go, itll sputter and i have to let off no matter how much gas. Wat can this be???
Old Feb 16, 2006 | 01:58 PM
Default Re: (silverboost)
Fu** it im sick of my old d-series givin me problems, im takin out the d16 this weekend and puttin in my b16 that i have in my garage from a totalled si
Old Feb 16, 2006 | 02:07 PM
GarageAlchemist
Guest
Posts: n/a
fmu.. huh.. sounds like you just ended up half assing the setup. I would just try to get it right the first time. Your going to give up a boosted d for a stock b16 cause you have a minor fuel problem.
good way to cave in on presure
Old Feb 17, 2006 | 03:53 AM
96hb's Avatar
Default Re: (GarageAlchemist)
It's not the motors fault that you have sh*tty fuel management.
Old Feb 17, 2006 | 12:00 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost &raquo;</TD></TR><TR><TD CLASS="quote">Fu** it im sick of my old d-series givin me problems, im takin out the d16 this weekend and puttin in my b16 that i have in my garage from a totalled si</TD></TR></TABLE>
Sweet. Swap in a slower setup because you can't solve a problem in 10 seconds. Why did you even post here and waste peoples time if you weren't even going to TRY?
1). You are using an FMU on stock injectors. Not good at all.
2). Are you the gauge with a 4 wire narrowband or at you using it with a wideband o2? I NEVER saw you say you are using a wideband anywhere in your posts
You can't just slap a turbo on something and ghetto rig it "just for now" and not expect problems.
Old Feb 18, 2006 | 03:52 PM
Default Re: (Hybrid93Eg)
actually im gonna boost the b16 but with proper feul management so itll be a faster setup, i was planning on not blowin all my $$ but instead wait a bit. But seein as i was havin problems i said screw it and the fmu and im gonna get tuned by Jeff Evans in PA.
Old Feb 18, 2006 | 04:20 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost &raquo;</TD></TR><TR><TD CLASS="quote">actually im gonna boost the b16 but with proper feul management so itll be a faster setup, i was planning on not blowin all my $$ but instead wait a bit. But seein as i was havin problems i said screw it and the fmu and im gonna get tuned by Jeff Evans in PA.</TD></TR></TABLE>
If you say so. Good luck with whatever you decide on.
blackccoupe
Mar 28, 2004 12:25 PM
hybridb18
Apr 21, 2003 10:46 AM
Boosted Gsr Hatch
Mar 15, 2003 06:47 AM
00SIBOOST
Jan 10, 2003 10:01 PM
mannysir
Sep 8, 2002 05:49 AM
