faster spool secrets
Old Aug 11, 2003 | 05:58 PM
yisoulja's Avatar
Default faster spool secrets
Ive got an LS-T $12000 worth of rebuild in it and I have a T04R turbo on it and its a street car. My redline is at 9k but i was wondering what i can do for faster spool. Im NOT lookin for full boost by 4k at all im just lookin to have the fastest spool i can with that turbo
thanks
john
Old Aug 11, 2003 | 06:08 PM
MiraiZ's Avatar
Default Re: faster spool secrets (yisoulja)
boost controller, header wrap, in extrme cases -get higher compression pistons larger exhaust
Old Aug 11, 2003 | 06:18 PM
Bailhatch's Avatar
secrets, huh? well just promise not to tell anyone, OK???
-bigger or no exhaust
-MBC at least
-correctly sized pipes and IC to minimize internal volume (ie. less is more) = faster response
-really open intake. short and sweet
-rev it hard then dump the clutch fo the hunnies Yo!!!
Old Aug 11, 2003 | 06:40 PM
Yosshaa's Avatar
you've spent 12k and turbo lag is still a problem?
Old Aug 11, 2003 | 06:42 PM
Kack's Avatar
Default Re: faster spool secrets (MiraiZ)
what does the Header Wrap and Boost Controller do to help spool up? The Boost controller just limits the boost.
Old Aug 11, 2003 | 06:50 PM
psileepR's Avatar
New User
Default Re: faster spool secrets (Kack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kack &raquo;</TD></TR><TR><TD CLASS="quote">what does the Header Wrap and Boost Controller do to help spool up? The Boost controller just limits the boost.
... lemme take a crack at this...
header wrap helps the manifold retain heat. hotter gasses = move faster
people wrap the dp as well up till the cat.
boost controller... mbc's are good at holding boost from my experience than ebc's. ebc's have a solenoid that manipulates vaccuum to help reach max boost sooner.
Old Aug 11, 2003 | 06:55 PM
Pelican's Avatar
Default Re: faster spool secrets (psileepR)
retard the timing and up the fuel
or
squeeze
Old Aug 11, 2003 | 07:12 PM
one more chance's Avatar
have dropped the vtec cut-in point..?
Old Aug 11, 2003 | 07:41 PM
drvfast's Avatar
bigger dp bigger exhaust
Old Aug 11, 2003 | 07:49 PM
steroidguy's Avatar
Port and polished head will flow more. Hence more air forced into the turbocharger. It should help on spool time.
Old Aug 11, 2003 | 08:14 PM
Smashback's Avatar
Default Re: (steroidguy)
The more you englarge the head ports the more bottom end you kill off, next...
Seriously, with that much money invested....your engine should handle a 50 shot of n2o just fine. Spray and pray baby. A 50 shot will also give a hefty increase on the dyno for a turbo motor.
Old Aug 11, 2003 | 08:19 PM
arsenaldragster's Avatar
Default Re: (PseudoSilvia)
heres a freebie.. keep the vaccum lines as short as possible
Old Aug 11, 2003 | 08:23 PM
falcongsr's Avatar
What is this crap?
Default Re: faster spool secrets (Pelican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pelican &raquo;</TD></TR><TR><TD CLASS="quote">retard the timing and up the fuel
best advice so far!
run 10.5:1 - 11:1 and pull 1.5-2 degrees of timing (or more) from 0-6psi or so and watch her spooooooool right quick.
basically you're burning fuel later so it increases exhaust pressure before the turbo and thats what makes a turbo spool.
Old Aug 11, 2003 | 08:38 PM
tony1's Avatar
Default Re: faster spool secrets (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
best advice so far!
Actually, from what i've seen and been told by very reputable tuners, this only works when there is no load on the motor. It works on a 2 step, but not on the dyno. I've always had best luck with more timing and less fuel until it the boost comes up...
lazerus's Avatar
Naws, really small turbine housing, high compression. ceramic coated downpipe, header, turbine housing with heat wrap. Short vac lines, more displacement, ball bearing turbocharger...
all kinds of things can do it!
Old Aug 11, 2003 | 08:41 PM
ek9vboi
Guest
Posts: n/a
i say oil change!
Old Aug 11, 2003 | 08:47 PM
Dee's Avatar
Dee
Default Re: (ek9vboi)
I guess nobody noticed the size of his turbo. T04R is kinda big for an LS. What is the size of your ex housing, DP and exhaust? What is your compression? Is the w/g open or closed. Answer those questions and you will probably get better replies
Old Aug 11, 2003 | 10:31 PM
u2civic1's Avatar
Default Re: (Dee)
use mobil one
Old Aug 12, 2003 | 12:37 AM
lazerus's Avatar
Default Re: (u2civic1)
hmmm t04r hmmmm spool issues? i think so!
Old Aug 12, 2003 | 02:58 AM
yisoulja's Avatar
Default Re: (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">I guess nobody noticed the size of his turbo. T04R is kinda big for an LS. What is the size of your ex housing, DP and exhaust? What is your compression? Is the w/g open or closed. Answer those questions and you will probably get better replies </TD></TR></TABLE>
3 inches from the turbo back, compression is 9.6:1 84.5 mm, open wg
Old Aug 12, 2003 | 03:09 AM
Dee's Avatar
Dee
Default Re: (yisoulja)
What exhaust housing? If you went larger than T4 O trim AR.58 that will be the source of your problems. T3 stage V AR.63 would work nice for a 9k rpm setup but it's kind of small for a T04R(62-1 blade) compressor. What head/cams are you using to rev to 9k rpm?
Old Aug 12, 2003 | 04:04 AM
Lost Type R's Avatar
Default Re: (Dee)
from what i heard.. smaller intercooler piping can help spool... but what do i kno.. its jus a guess...if you can invest 12000 into ur car... a guaranteed answer would be to invest in a Garrett GT30 or SC61.
Old Aug 12, 2003 | 04:32 AM
Civic TSI's Avatar
Default Re: (Lost Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">people wrap the dp as well up till the cat. </TD></TR></TABLE>
You don't want to do that, it will increase the lag. Wrapping the manifold is good, not the downpipe. People who wrap the downpipe don't know **** about how turbo works.
Old Aug 12, 2003 | 04:34 PM
falcongsr's Avatar
What is this crap?
Default Re: faster spool secrets (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, from what i've seen and been told by very reputable tuners, this only works when there is no load on the motor. It works on a 2 step, but not on the dyno. I've always had best luck with more timing and less fuel until it the boost comes up...</TD></TR></TABLE>
tony my spool time slowed down when i went from 11:1 and 2 degrees of retard to 12.5:1 and 0.6 degrees of retard. this also fixed my boost spiking/creeping.
please no jokes about how retarded i used to be.
Old Aug 12, 2003 | 05:14 PM
-iLLuZioN-B18C1's Avatar
how bout full race mani?
