Nitrous ..
Old Jun 24, 2002 | 05:30 AM
Creim_si's Avatar
Default Nitrous ..
I have checked around and got mixed thoughts.
1. Direct port wet system 100 shot.
2. Fuel pump, clutch, plugs, ect.
3. stock bottom end.
Good idea ? bad idea?
Old Jun 24, 2002 | 05:53 AM
S2Kpower's Avatar
Default Re: Nitrous .. (Creim_si)
a little timing retard and everything should hold up pretty well
Old Jun 24, 2002 | 05:58 AM
PM-Performance's Avatar
Default Re: Nitrous .. (S2Kpower)
im working on mine now , as long as you got the fuel and timing down, 100 shot is no prob.
just make sure you get it on the dyno before you start sprayin it . i know quite a few guys doin it though
Old Jun 24, 2002 | 06:01 AM
Crxless's Avatar
I wouldn't run a 100hp shot on a stock bottom end. Maybe if I wasn't going to use the nitrous alot but even then I wouldn't want to unless I had the money to replace the motor. I would see how the motor handles a 50-75hp shot first and work up from there.
I do agree that a well tuned motor would make it much more possible to run a 100hp shot without problems but I still feel that's pushing it a little. The miles on the motor and the condition of the motor are factors to consider also.
[Modified by Crxless, 10:10 AM 6/24/2002]
Old Jun 24, 2002 | 08:19 AM
Default Re: Nitrous .. (Crxless)
make sure the compression is cool and **** . . . check the motor out, but like i said , i know alot of people with 100+ shot and they are running fine.
8083tcman
Jan 16, 2009 11:56 AM
vmsturbo
Aug 21, 2004 06:29 PM
DOHCRX
Mar 18, 2004 12:24 PM
aandDavidsaid
Dec 21, 2003 10:05 PM
NewbieGuy
Oct 11, 2001 08:24 AM
