A/F ratio when not in boost.... suggestions?
Old Dec 7, 2002 | 04:02 PM
echo999's Avatar
New User
Default A/F ratio when not in boost.... suggestions?
For those who street tune... what a/f do you guys tune for out of boost?
I see alot of people shooting for 12:1 when under boost, but I don't hear much
about out of boost situations.
Also I'm hearing that honda engines like to cruise/idle REAL lean... in the range of 15-17 a/f...
Thanks for any help.
Old Dec 7, 2002 | 04:05 PM
TurBoXBirD16's Avatar
Default Re: A/F ratio when not in boost.... suggestions? (echo999)
14.7 is the normal one
Old Dec 7, 2002 | 04:06 PM
98civicEX's Avatar
i "believe" that 14.0 is stoich, and is what they shoot for when out of boost...this is a BELIEVE, i may be completely wrong....but just posting MO
Old Dec 7, 2002 | 04:10 PM
ekb18c's Avatar
12:1 is a pretty good ratio to try to obtain.
It will depends on the motor and parts on the motor though. Every motor is different, you just have to see.
Some motors may be more efficent while others aren't. If a motor is really efficient then it will want more and more fuel.
Old Dec 7, 2002 | 04:59 PM
BudaKai's Avatar
Default Re: A/F ratio when not in boost.... suggestions? (ekb18c)
I run 13.5:1 mearly to clean up the emissions while idling and to extend my plug and o2 life as much as possible. I found that with 14:1 it likes to run a little lean when you first get on it. Datalogging EGT's was a good idea. My wide-band never pick up the drop, but I figure it was dropping to around 15.5:1 when I just jumped on it.
Old Dec 7, 2002 | 06:04 PM
falcongsr's Avatar
What is this crap?
Default Re: A/F ratio when not in boost.... suggestions? (tzsir)
you should aim for 14.7:1 while cruising.
i am aiming for 15.5 at very light loads to conserve fuel. i think this is how honda's "lean burn" civic VX worked. it just leaned out under light loads, since you wont detonate at light load and leaner than 14.7. EGTs are not getting out of hand. a document on the web quotes Bosch as saying you can go as lean as 16.2:1 for fuel economy, but thats a little much in my opinion. also running lean causes a spike in NOx emissions which can eat metal in the exhaust etc. but thats a long-term concern.
Ghunt521
67
Jan 27, 2012 02:56 AM
IntegraType-R
Oct 6, 2006 04:57 PM
B16Civic93
Jul 13, 2005 02:12 PM
ezark
Jan 11, 2002 09:55 AM
