A/F problems Please help
Old Jan 9, 2010 | 08:10 PM
andrew54's Avatar
Default A/F problems Please help
I was out driving today and i came up to a stop sign and my A/f ratio was up to 17 then i got over to my friends house turned it off and then restarted it it was doing the same thing but would go start at 16.0 up to 19.3. This is only at idle when this happens. When I am driving it says in the 14.5- 15.5 with partial throttle which is normal. When I boost it goes to 11.7 which is normal.
I checked the resistors they were all good.
The plugs all look good.
I checked the wide band with brake fluid and it worked.
I cannot find any vacuum leeks.
It ran good the last time i drove it last week no problems.
I have drove around just under 5000 miles on this motor and tune.
This is in my Acura Integra
gsr block 81.5mm
sc61-1 turbo full race manifold
Precision 880cc injectors
walbro fuel pump
aem ems
aem serial guage
aem uego
Please help with advise or where to start
Thanks
Old Jan 9, 2010 | 08:19 PM
kyden's Avatar
Default Re: A/F problems Please help
does it run any different? could be your sensor going bad.
Old Jan 9, 2010 | 09:22 PM
andrew54's Avatar
no the car seems to be running fine i checked the o2 sensor and it is working properly
Old Jan 10, 2010 | 08:55 AM
Turbo-LS's Avatar
Weather charges IE intake temp will change the tune somewhat. Go into the aem software and adjust intake temp corrections table as needed at idle only. you say your a/f are good in part throttle and wot so only adjust idle corrections
Old Jan 10, 2010 | 05:13 PM
heavy duty's Avatar
I have seen a air leak in the ex before the o2 do that so check that.
Old Sep 6, 2012 | 09:22 AM
spikey6969's Avatar
Default Re:
I have a different type of question I am thinking bout buying a 94 integra gsr and the problem with it is that the tach, speedometer and gas guage dont work on the dash what cud the problem be
johnsc2235
Jun 10, 2008 04:59 PM
c61lude
Feb 1, 2005 09:19 AM
BlueSi2k
Dec 23, 2003 07:31 AM
echo999
Jul 23, 2002 08:40 AM
