external wastegate installation question......
Old Jul 4, 2003 | 07:50 AM
eg6nos's Avatar
Default external wastegate installation question......
how do u install a external wastegate.....there a boost fitting and a vacuum fitting....where does these go to and how do u hook it up.....any info will help...
Old Jul 4, 2003 | 07:55 AM
Pritos's Avatar
New User
Default Re: external wastegate installation question...... (eg6nos)
what type of wg is it? the vac fitting on top isn't used unless you're running an EBC.
Old Jul 4, 2003 | 07:58 AM
Pritos's Avatar
New User
Default Re: external wastegate installation question...... (Pritos)
ohoh, if you dont have any type of boost control, mb or ebc, then attach the compressor housing nipple to the boost fitting on the wg.
Old Jul 18, 2003 | 10:18 AM
luti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pritos &raquo;</TD></TR><TR><TD CLASS="quote">ohoh, if you dont have any type of boost control, mb or ebc, then attach the compressor housing nipple to the boost fitting on the wg.</TD></TR></TABLE>
Should I take the line from the compressor housing or from the manifold? Wouldn't it be more accurate from the manifold since I will be running it through an intercooler?
Old Jul 18, 2003 | 05:42 PM
luti's Avatar
Default Re: external wastegate installation question...... (luti)
ttt
Old Jul 19, 2003 | 09:01 AM
luti's Avatar
ttt again
Old Jul 19, 2003 | 09:23 AM
Adriano's Avatar
If you take it from the manifold, it will be more accurate. Pressure is usually lost between the turbo and manifold.
1fastlude1
May 2, 2008 01:40 PM
hotrod99
Jun 13, 2007 04:01 AM
marcussmith26
May 15, 2006 08:21 AM
RACEPAK
Mar 31, 2006 10:00 AM
Nextelbuddy
Mar 26, 2004 01:20 PM
