External wastegate on hf manifold??
Old Oct 5, 2004 | 04:59 PM
1boostedcivic's Avatar
Default External wastegate on hf manifold??
has any one tried an external tial wastegate on an hf manifold. like weld it on and customize ur own flange?? Would the manifold crack, has anyone tried it with success????
Old Oct 5, 2004 | 05:03 PM
MooreBoost's Avatar
Default Re: External wastegate on hf manifold?? (1zexxedcivic)
Ive seen it done a few times before over at HMT, but the way the did it was apparently not acceptable, brazing maybe?
Old Oct 5, 2004 | 05:04 PM
Default Re: External wastegate on hf manifold?? (tegunderpressure)
brazing? what is that? if u dont mind explaining
93turbo16's Avatar
I honestly just thought about doign thins sometime, just to try it. You would have to heat the manifold up to about where you would weld it at. It would probably end up cracking anyway. Only other way would somehow make a plate that sat flush on the manifold and tapped it. BUt still probably would crack. Decided just to make a custom manifold. Brazing is usually when you take a torch, not a welder and braze the two metals together, I think that is pretty much what it is. Usually uses a filler rod type thing, like tig welding.
Old Oct 5, 2004 | 05:08 PM
Bailhatch's Avatar
Default Re: (93turbo16)
Or you could run an external off a 5 bolt t3 flange or a DSM 14b or t25. Port the hole out to roughly the same size as the inlet of the WG and it should work OK without having to mess with the HF manifold.
Old Oct 5, 2004 | 05:15 PM
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">Or you could run an external off a 5 bolt t3 flange or a DSM 14b or t25. Port the hole out to roughly the same size as the inlet of the WG and it should work OK without having to mess with the HF manifold.</TD></TR></TABLE>
cause i have a tial 35mm and im tired of this creepy internal so im going to try this. but the turbo is a saab t3 50 trim .42, .48
Old Oct 6, 2004 | 11:51 AM
up
Old Oct 6, 2004 | 01:43 PM
Bailhatch's Avatar
Default Re: (1zexxedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic &raquo;</TD></TR><TR><TD CLASS="quote">
cause i have a tial 35mm and im tired of this creepy internal so im going to try this. but the turbo is a saab t3 50 trim .42, .48</TD></TR></TABLE>
that the same turbo I run but with a .63 a/r housing. works fine with a ported internal for me...
anyway, since you have the .48 a/r housing (which would be like $20 to replace) you should try my idea. hog out the WG hole and weld an external gate flange to the 5 bolt flange bolt on external WG project - done.
Old Dec 2, 2004 | 02:13 PM
ttt
96electronH
Mar 21, 2011 04:44 AM
sasinorm01
Mar 14, 2008 08:14 PM
Dc4turbo408
Welding / Fabrication
31
Jul 8, 2006 08:50 PM
dturbo
May 10, 2005 08:26 PM
Patron
Feb 13, 2004 08:35 AM
