external knock sensor??
Old Dec 11, 2004 | 07:05 AM
goose21's Avatar
Default external knock sensor??
Hi, i have a b16turbo with p28 ecu with hondata. But i want a knocksensor.
And i dont want one that changes my ignition by itself. I want an external one with a monitoring guage or something to read the knock level from(if there is any)
Is there such a unit???
thanks Jose
Old Dec 11, 2004 | 08:29 AM
sleepin91teg's Avatar
Default Re: external knock sensor?? (goose21)
Doesnt sound like its out there...but im not sure why you would want this anyways...p28 do not have a knock board...
Old Dec 11, 2004 | 08:43 AM
goose21's Avatar
Default Re: external knock sensor?? (sleepin91teg)
The reason i want one is that i tuned my car @ the dyno. But the temperature
varies alot here. So i'm scared that when it gets alot warmer outside, i will start detonating. And also just to be save i want a knock sensor. And i want a external one with a gauge because the p28 doesn't support this.
Old Dec 11, 2004 | 08:44 AM
t04ecvc's Avatar
MSD makes a knock count unit, but yopu have to use an adapter to mount it to your block.
Old Dec 11, 2004 | 09:03 AM
631 Teggy's Avatar
Default Re: external knock sensor?? (t04ecvc)
I'm interested as well.... Where can one buy a knock sensor that runs independantly..?
Old Dec 11, 2004 | 09:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: external knock sensor?? (631 Teggy)
caspers has one but it uses a gm "microphone" style sensor. i am pondering an install on mine but i need to find a place i can put a 1/4 NPT hole to accept the sensor.
Old Dec 11, 2004 | 09:21 AM
f22b2tdave's Avatar
the ultrasafeguard
http://www.jandssafeguard.com/
external and well trusted knock sensor and retards your timing per cylinder as well.
worth the money, it will be my next investment. bout 500 bucks or so ive seen them for.
dave
Old Dec 12, 2004 | 09:51 AM
goose21's Avatar
Default Re: external knock sensor?? (f22b2tdave)
i looked @ the savegaurd. But i dont need al the options its gives. And i dont want it to change my ignition. I just want to monitor my knock level
Does anyone use the msd one???
Old Dec 12, 2004 | 06:04 PM
631 Teggy's Avatar
Does MSD have a knock sensor with guage?
Old Dec 12, 2004 | 06:16 PM
dennis's Avatar
Doesn't a b16 have a knock sensor? I don't know - I'm an accord guy. Anyway, what's wrong with just aquiring a knock sensor, mounting it to your block and use a volt meter to monitor. Something to datalog would be better - some volt meters do that. Just an idea.
Old Dec 12, 2004 | 06:33 PM
Mr. Badwrench
Default Re: external knock sensor?? (dennis)
b16's do but if you arent using a p30 p72 or p73, like most of us using hondata we have p28's. p28's dont use a knock sensor.
1sikhatch
Aug 17, 2010 08:20 AM
h22lude317
May 22, 2009 08:58 PM
hatch2000
Sep 21, 2006 03:19 PM
96 GSR-T
Jun 30, 2006 09:31 PM
92ludeport
Jul 8, 2005 02:08 PM
