explain "pre-loading"
Old Sep 21, 2006 | 08:49 PM
spoolin_teg's Avatar
Default explain "pre-loading"
I dont have slicks at the time and having trouble with traction...ha! imagine that eh. But...when you "pre-load" what are you holding the RPM's at? explain in details, I wanna try it at the track tomorrow. If your not launching at high rpm's wouldnt the turbo have soo much lag and just fall on its face? Im a good driver, but I cant figure out a better way for traction on the track. Anyone and everyone's .02cents is needed.
Old Sep 21, 2006 | 09:05 PM
BoostedJeff's Avatar
Default Re: explain "pre-loading" (spoolin_teg)
preloading is more for prevention of drivetrain shock. not so much for traction.
Old Sep 21, 2006 | 09:30 PM
Default Re: explain "pre-loading" (BoostedJeff)
can you explain it? I destroyed my ls tranny, now I have a type R and dont wanna do the same.
Old Sep 21, 2006 | 10:04 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin_teg &raquo;</TD></TR><TR><TD CLASS="quote">sharpsville pa.</TD></TR></TABLE>
hmmmmmmm
Old Sep 21, 2006 | 10:10 PM
Default Re: explain "pre-loading" (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">hmmmmmmm</TD></TR></TABLE>
Old Sep 21, 2006 | 10:18 PM
EFn JP's Avatar
well on slicks and doing my thing idk if i consider it preloading or not, but i just put it in first at the line and rev up to 5000rpms(i suggest u do less) and let the clutch out a bit til it starts gripping a bit so tugs you forward, loading the read suspension and setting weight off the front, and then when its the 3rd amber (idk what u sholuld look for) i drop the ebrake and fully let the clutch out and floor it, and get ready to **** to 2nd, well thats my 2 cents idk thats worked best for me not to break exles, im sure it wears the clutch a lil bit though
Old Sep 21, 2006 | 10:20 PM
Default Re: explain "pre-loading" (BoostdCivic214)
make sure you have a clutch that will handle some slippage
Old Sep 22, 2006 | 04:28 AM
I got a SPEC stage 3
Old Sep 22, 2006 | 05:39 AM
B6tizzleHatch's Avatar
heres what i do: get both staging lights lit up, find where i wanna launch (4-4300ish) pull up the ebrake but keep the button in (in other words dont yank it and leave it up, use some muscle and hold it up with the button in) let the slack out on my clutch until im almost to where it grabes, then when the light goes do your thing.... you will proabaly get some pretty good 60fts also
Old Sep 22, 2006 | 11:28 AM
turbo_ls_69's Avatar
Default Re: explain "pre-loading" (B6tizzleHatch)
wouldnt he just spin then? cuz hes on street tires at 4k with ebrake up?
Old Sep 22, 2006 | 11:42 AM
See Are X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have a clutch that will handle some slippage</TD></TR></TABLE>
yessir...I just burnt out my clutch last weekend preloading at 5500rpm. Could be the fact that my clutch is over 3 years old also.
Old Sep 22, 2006 | 06:12 PM
HamiltonRex's Avatar
Default Re: explain "pre-loading" (See Are X)
dont worry about preloading if your not on slicks.. It wont help you with traction and your street tires wont hook enough to hurt anything.
Old Sep 23, 2006 | 10:20 AM
Default Re: explain "pre-loading" (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">dont worry about preloading if your not on slicks.. It wont help you with traction and your street tires wont hook enough to hurt anything.</TD></TR></TABLE> HA! thats not what my tranny said...exploded the gears and put a 1x1 inch hole in the casing...soo...its not gonna help on street tires then? : (
Old Sep 23, 2006 | 10:24 AM
See Are X's Avatar
I dont know how true this is...but launching at 5500rpm, even on street tires, still puts a BIG jolt to the drivetrain
Old Sep 23, 2006 | 10:25 AM
N20civicB18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin_teg &raquo;</TD></TR><TR><TD CLASS="quote"> HA! thats not what my tranny said...exploded the gears and put a 1x1 inch hole in the casing...soo...its not gonna help on street tires then? : (</TD></TR></TABLE>
Its an LS tranny thing, they all do that
Old Sep 23, 2006 | 10:29 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know how true this is...but launching at 5500rpm, even on street tires, still puts a BIG jolt to the drivetrain</TD></TR></TABLE>
yeah but preloading takes the "slack" out of the drive train.
preloading also helps with weight transfer (by loading the rear suspension) so it can help on street tires or slicks, doesnt matter, which can help in your 60fts.
Old Sep 23, 2006 | 11:37 PM
guess ive been lucky with mine thus.
jjspec
Jun 15, 2008 08:53 PM
underpressure02
May 11, 2007 07:29 AM
scratchy
Sep 28, 2004 08:04 AM
adrenalinjunkie
Jul 2, 2004 12:49 PM
dclsvtec
Jun 1, 2004 03:10 PM
