Exhaust temps too high??
Old Nov 13, 2005 | 02:09 AM
ozzyman's Avatar
Default Exhaust temps too high??
My setup consists of a H22 turbo on AEM EMS. EGT gauge is a Defi D Gauge and probe is 1" away from the flange on #3 exhaust runner. The drivability was tuned by Carlos aka 'Bubba' from Do It Dyno.
Now at idle my cars EGT is about 800F. When I'm driving under 3200rpms with a load, I can get my EGTs up to about 1500F if I really wanted to. Who knows.. maybe even higher. The funny thing is when I'm above 3200rpms it wont go above 1400F, even under boost. I usually have to downshift if theres a slight incline on the freeway when I'm going 60mph, because its right at 3000rpms, and when I give it load, the EGTs will climb up before my RPMs so I cant get it to stay at 1400F. I was wondering if I had a problem here? I always watch the gauge and make sure it doesnt get above 1400, but its a pain downshifting all the time just to get the temps down.
Should I try advancing it? Any suggestions? Will it still be safe to hook up a wideband O2 without damaging the sensor?
Old Nov 13, 2005 | 06:48 AM
Sketch_hs's Avatar
i see 1400-near 1500 at part throttle cruise on the freeway
Old Nov 13, 2005 | 12:11 PM
ozzyman's Avatar
Default Re: (Sketch_hs)
Anyone else have any input?
Old Nov 13, 2005 | 12:17 PM
rudebwoy's Avatar
I read in a manual that piston engines run 1500*f normal. mine gets up to 1600* at 18psi around 7200rpm and up. 800*f-idle 1300*f part throttle
Old Nov 13, 2005 | 12:25 PM
ozzyman's Avatar
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I read in a manual that piston engines run 1500*f normal. mine gets up to 1600* at 18psi around 7200rpm and up. 800*f-idle 1300*f part throttle</TD></TR></TABLE>
Are you serious? I thought 1600F was the melting point for pistons. Was I told wrong?
Old Nov 13, 2005 | 12:57 PM
rudebwoy's Avatar
Old Nov 13, 2005 | 12:59 PM
rudebwoy's Avatar
since I dont have the manual, this might help.
https://honda-tech.com/zerothread?id=248965
http://www.hydrogen-boost.com/june2004.html
X2BOARD
Dec 7, 2007 08:16 AM
navz121
Dec 5, 2003 07:24 AM
11secdx
May 21, 2003 08:41 AM
Infinity_Racer
Mar 27, 2003 03:21 AM
Pro-Lude
Jul 31, 2001 04:10 AM
