Exhaust leak need some tips
I purchased a maxrev manifold from ben at import parts and i am having a problem. The tial wastegate i bought will not sit flush on the flange on the manifold. I already ruined the gasket that it comes with, so i made a new gasket from stainless steel sheet. Still having a monor exhaust leak problem. Is there any kind of liquid gasket sealent aid that i can use along with the gasket to help seal the leak, thats not gonna melt from the heat. As far as i know the only thing arounf is RED RTV that withstands 600 degrees, and i am not sure if that is enough. please help if you can. Thanks
More than likely the W/G flange is slightly warped, you would need to get it re-planed (cheep) Otherwise you will keep killing those $3 gaskets and springing a leak. Lay the flange on a completely flat surface or use a leveller to check it's 'flatness'. If you suspect a part of the flange, use feeler gauges to identify potential warpage. I wouldn't really recommend using a band aid fix as a W/G leak is not the same as a simple exhaust leak. But if you must, copperseal might help.
