EVO VIII Injectors
Old Feb 24, 2006 | 05:52 AM
fjt's Avatar
fjt
Default EVO VIII Injectors
*searched* just 1 topic with no specific answer..
Do you guys know if the EVO VIII injectors fit a civic? Do i use a resistor box just like DSM 450's?
How many CC are they?
Old Feb 24, 2006 | 06:50 AM
Schister66's Avatar
Man U FTW
I'm going to guess that they're 450cc stock and you won't need a resistor pack, but that's just a guess.....
Bump for info!
Old Feb 24, 2006 | 06:58 AM
ITR9788's Avatar
I want to say 550. I run them over them in my GSX.
Old Feb 24, 2006 | 07:02 AM
Schister66's Avatar
Man U FTW
Are they 550's?? I just thought that since it is a DSM (basically) it would have the same injector size.....plus a 450 would support the power an Evo makes....
Old Feb 24, 2006 | 07:09 AM
splitime's Avatar
Default Re: (Schister66)
Running some right now FJT... off a newer evo8 MR.... 560 is on the serial (so either 550cc or 560cc)... and they fit right in place of my 450s.
Old Feb 24, 2006 | 07:16 AM
mrbigg9032's Avatar
Are they a direct swap if not what do u need to change???
Old Feb 24, 2006 | 07:19 AM
splitime's Avatar
Default Re: (mrbigg9032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbigg9032 &raquo;</TD></TR><TR><TD CLASS="quote">Are they a direct swap if not what do u need to change???</TD></TR></TABLE>
If you are already running DSM injectors and a resistor box (stock for obd0)... then they are just a plug/play... and RETUNE
Old Feb 24, 2006 | 07:37 AM
fjt's Avatar
fjt
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Running some right now FJT... off a newer evo8 MR.... 560 is on the serial (so either 550cc or 560cc)... and they fit right in place of my 450s.
If you are already running DSM injectors and a resistor box (stock for obd0)... then they are just a plug/play... and RETUNE </TD></TR></TABLE>
You rock dude!!! Thanks.. so i can just swap them in place of my DSM 450's.
so theyre 560CC?
Im shooting for 300+whp.. would you say theyre good for 300-325whp?
Old Feb 24, 2006 | 07:40 AM
splitime's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">You rock dude!!! Thanks.. so i can just swap them in place of my DSM 450's.
so theyre 560CC?
Im shooting for 300+whp.. would you say theyre good for 300-325whp?</TD></TR></TABLE>
Considering people say the 450s are just ok for 300... I believe the 550s should be fine for more... if anything you can run a higher fuel psi from the start also... and just tune for it.
I literally took my 450s out, put the 550/560s in and redid my maps and started it up. Car seems like it responds nicer also... unsure if thats due to newer injectors... or that they are of a design that sprays a better pattern.
Old Feb 24, 2006 | 02:49 PM
mchuang's Avatar
They are 560cc, I know for sure
Old Feb 24, 2006 | 03:04 PM
Jay_Sensing's Avatar
Ditto, a guy at my local shop is a DSM freak and I used to be one as well. 560 it is.
Old Feb 24, 2006 | 04:42 PM
1.8t's Avatar
Default Re: (Jay_Sensing)
They are 560's.
Old Feb 27, 2006 | 05:23 AM
fjt's Avatar
fjt
Default Re: (1.8t)
well i found some info from a guy that works with Evos here.. He said that the 2002-2003 EV0 VIII injectors are 560cc and the 2004-2005 EVO are 575cc.
Splitime..How much you got your injectors for? Anyone know how much they sell for?
Old Feb 27, 2006 | 05:38 AM
rkeith's Avatar
Default Re: (mchuang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">They are 560cc, I know for sure </TD></TR></TABLE>
Yes, they are indeed 560's.
Old Feb 27, 2006 | 06:02 AM
splitime's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">well i found some info from a guy that works with Evos here.. He said that the 2002-2003 EV0 VIII injectors are 560cc and the 2004-2005 EVO are 575cc.
Splitime..How much you got your injectors for? Anyone know how much they sell for?</TD></TR></TABLE>
Mine had 7000miles on them... got them locally for 130. Sold my 450s for 50... so I figure I got them for 80bucks ;p. I think they usually tend to go for closer to 200 used though.
Old Feb 27, 2006 | 06:13 AM
fjt's Avatar
fjt
130 sounds good man..A guy locally wanted 200(discounted from 275) for his EVO 575cc inj.
mortificationrock
Jun 10, 2007 09:05 PM
b17a1crx
Sep 10, 2006 07:27 PM
b16hatche
Oct 24, 2005 08:03 PM
sivik2nr
Jun 11, 2003 09:59 PM
boostin b16
Jan 19, 2003 08:27 PM
