Evo fmic on Del Sol
Old Oct 9, 2005 | 10:39 AM
dohcdelsol93's Avatar
Default Evo fmic on Del Sol
I just installed the evo fmic on my sol paired with a t3/t4 turbo and a Love Fab mini me eq mani. Do these charge pipes look too low? Thanks to the frame, low sitting mani, and goofy end tanks I couldn't get it any lower.
[IMG][/IMG]
click on pic for full size image
Question #2. This is an ls/vtec using the ls oil pan. Is there anyone else running this manifold on an ls or ls/vtec and how did you guys run your oil return?
Modified by dohcdelsol93 at 11:18 AM 10/10/2005
Old Oct 9, 2005 | 12:48 PM
spectacle's Avatar
Default Re: Evo fmic on Del Sol (dohcdelsol93)
looks good
Old Oct 9, 2005 | 01:48 PM
RNPoo7's Avatar
mmmm buhO:-) lol
Josh that looks great.
Those charge pipe are by no means lower than how my charge pipe used to be on my teg. If you could raise them some, that would be great, if not, i highly doubt you will have a problem.
Old Oct 9, 2005 | 01:49 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: Evo fmic on Del Sol (spectacle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">looks good </TD></TR></TABLE>
i agree.
try some silicone 45*'s off of the inlet/outlet, to keep the charge pipes up.
Old Oct 9, 2005 | 03:47 PM
B16CRXT's Avatar
Default Re: Evo fmic on Del Sol (PhoenixTurbo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurbo.com &raquo;</TD></TR><TR><TD CLASS="quote">
i agree.
try some silicone 45*'s off of the inlet/outlet, to keep the charge pipes up. </TD></TR></TABLE>
Good idea. Either that or have someone tig those angle pipes on teh endtanks at a differnt angle. Lookin good Josh. Let me know when you want to go tune.
Old Oct 9, 2005 | 04:02 PM
m R g S r's Avatar
lovefab coated manifold yet an evo fmic?
i dont get it....
anyway, it would suck to have one of those dented up badly by hitting something such as a rock or parking block, i would get the endtank outlets of the intercooler cut and re-welded
Old Oct 9, 2005 | 05:48 PM
AbitAvenger's Avatar
Default Re: Evo fmic on Del Sol (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">lovefab coated manifold yet an evo fmic?
i dont get it....
anyway, it would suck to have one of those dented up badly by hitting something such as a rock or parking block, i would get the endtank outlets of the intercooler cut and re-welded </TD></TR></TABLE>
He obviously spent all his money on the mani
And plus the evo fmic is pretty nice.
charge pipes are lower then usual but i think you should be ok, woulndt hurt to fab something up to make em higher just for the piece of mind tho, post more pics and numbers
Old Oct 9, 2005 | 06:05 PM
2LiterTurboSeR's Avatar
Default Re: Evo fmic on Del Sol (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">
charge pipes are lower then usual but i think you should be ok, woulndt hurt to fab something up to make em higher just for the piece of mind tho, post more pics and numbers </TD></TR></TABLE>
All of the Evo owners local to me are still running the stock FMIC, and they are well into the 11 sec. timezone in the 1/4 mile, so I don't really see what the problem is... Lovefab = $$$
Nice setup
Old Oct 9, 2005 | 06:25 PM
v-tec maz's Avatar
looks awesome
Old Oct 10, 2005 | 10:17 AM
Default Re: Evo fmic on Del Sol (v-tec maz)
I got a good deal on the fmic and thanks to my boy B16crxt I got a killer deal on the mani, I just had to fork out alot of extra dough on the 44mm wg. I've heard mixed reviews on the evo fm but all of the negatives were brothers uncles cousins problems.
I'll probably go with cutting and then re-welding the end tanks straight and take the pipes around the side of the frame on the passnger side and then doing a rear inlet on the driver side because the driver side is already as low as it can possibly go thanks to that well hung mani. Thanks for the help guys.
Oh and bump on the question #2, I will be tackeling the oil return problem tonight weather pending
Tunning is planned next thur. as long as J.Davis is still avaliable
Old Oct 10, 2005 | 10:55 AM
wantboost's Avatar
Who is Mr Robot?
why are you running a 44mm? a 38 would be more than neough for your setup
Old Oct 10, 2005 | 11:25 AM
RNPoo7's Avatar
Default Re: Evo fmic on Del Sol (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">why are you running a 44mm? a 38 would be more than neough for your setup</TD></TR></TABLE>
The manifold came with a 44mm wg flange.
Old Oct 10, 2005 | 05:17 PM
B16CRXT's Avatar
higher resale value
Old Oct 10, 2005 | 06:39 PM
MooreBoost's Avatar
Default Re: Evo fmic on Del Sol (B16CRXT)
EVO frontmounts are incredibly efficient.
Old Oct 10, 2005 | 08:02 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: Evo fmic on Del Sol (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">EVO frontmounts are incredibly efficient.</TD></TR></TABLE>
upto 400whp imo
so efficient, that we only offer 1 upgrade, 24"x12"x3.5", good for upto 800whp
btw, i have a factory 05 EVO8 fmic for sale, only 50 miles on it
Old Oct 11, 2005 | 05:18 AM
upto 400whp imo
My goal is 300-350 to the wheels on a built ls/vtec so the stock evo front mount should be plenty for my needs. The only reason I have a 44mm wg, as stated before, because I got a killer deal on the mani and it had been flanged for the 44mm. Cody said that if I ran a 38mm it would ruin the jet coating for some reason. He knows his stuff so I went with it.
Old Oct 11, 2005 | 07:48 AM
hawjdude's Avatar
Evo fmic is good up to almost 400whp, nice look on your Sol.
Old Oct 11, 2005 | 07:59 AM
GeeGee's Avatar
very nice, what's wrong with your header bolts on runner two and three?
Old Oct 11, 2005 | 08:18 AM
Default Re: Evo fmic on Del Sol (Lycanthrope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lycanthrope &raquo;</TD></TR><TR><TD CLASS="quote">very nice, what's wrong with your header bolts on runner two and three?</TD></TR></TABLE>
First of they are studs, not bolts
I don't know if the pic is detailed enought for you to see but runners 2 and 3 have a slot cut in the mani instead of a hole. This is because the runners go uppward and toward the hood before they go back down to the collector making it a tight fit. So smaller bodied nuts on shortened stock studs were needed to even get the nut started and to keep the nut from hitting and messing up that nice jet coat finish. You can't get laid with a scratched manifold!
Old Oct 14, 2005 | 04:38 AM
RNPoo7's Avatar
Josh, any updates?
Old Oct 14, 2005 | 07:27 AM
Default Re: (RNPoo7)
taking care of oil return now, almost done
You Know I Got SOL!
May 14, 2004 03:09 PM
DELshow
Dec 14, 2003 09:21 AM
Farrell
May 22, 2002 02:49 AM
