H: 89x90.7 vs 87x95 Difference? Theory?
A question was asked by a local friend of mine about the 89x90.7 build. I went a step further and added the 87x95 to the equation.
Assuming same compression and surrounding mods, what difference would be seen if any?
89x90.7/143mm rod=2257cc/1.58 r/s ratio
87x95/141.5mm rod=2259cc/1.49 r/s ratio
Seems like the 90.7 stroke would be kinder to higher RPM.....and dwell would be better for air-flow.
And the 87x95 would beat up bearings more.....
Discuss......
Discuss......
Re: H: 89x90.7 vs 87x95 Difference? Theory?
well i guess it matters what the engine's purpose is the 95mm is more than likely going to make more low end torque and fall off up top
I'm sure there are people that are going to say otherwise and throw a whole bunch of theory into this. 9 out of 10 times those guys dont have the proper data and testing to validate those theories tho. Lol
If you search on here you can find a lot of debates that were had about r/s ratio. From what I took of it, it's just a number that really doesn't factor much into a street motor, considering there are cars with 1.4 and on kicking ***.
I know it's a theory not developed on HT. But it's a theory VERY FEW have proved and disproved, and Im sure even fewer are willing to give that kind of info out.
Considering the majority of us are building street motors and not race motors for different types of racing event, I'm sure we won't benefit from pouring alot of time $$$ and resources into testing an ideal r/s ratio.
yes. i would say 89x90 would be better for an all motor app and the 87x95 would be nice for a lower rpm long geared turbo setup
Well then what would you consider ideal ?
http://www.fordmuscle.com/archives/2...ker/index2.php
Yes, its got to do with the angle the rod is pushing on the crank and for how long. The bigger crank swings a bigger circle, its almost like a gearing thing if you think about it.
The r/s ratio is pretty insignificant if you ask me. In some motors yes, but if you actually draw up the difference in angles it is VERY minimal between these two and I dont believe its worth addressing on a street motor.
1 Post
the H: means its an H-series setup?
on a K-series utilizing the VTC it makes a difference, and the 1.4 rs setup can even win, but with the H and B-series with "fixed" cam timing, the relative RPM/airflow is a constant based on overlap due no adjustability of the cam's timing events, so the longer RS setup might be prone to win.
If its on a Skyline or Porsche motor with both intake and exhaust cams have adjustable cam timing, the RS difference prolly wont matter.
then you also never accounted for using the same camshafts too...that makes a huge difference because you can make a cam best suited for the 1.4 and a cam best suited for the 1.58
BTW 1.58 vs 1.4 isnt that huge of a difference.
again dyno or HP numbers won't be the only deciding factors...
gotta love benchracing lol.
Anyone and everyone can come up with and shoot down theory's until their face turns blue. Without proper testing, it all means squat.
alright who has 2 h22's laying around and some cash to burn someone has to do this test now. and like said, i think cams are going to make power difference between the two
Cams would deffinately do different things on each motor, but alot of that could be helped by adjustable gears too. What works for one may not be what works for the other.
That would be quite the dyno test haha
The only way that test would be feasible would be on an engine dyno. But you would also have to tailor each engine to their strong suits. so i would image that the cams, im, headwork, exhaust set up on one motor configuration wouldnt be ideal on the other. Lol thats alot of work to conduct a test just so we can say " well X worked on the dyno compared to Y, now lets see if that means anything on the track LOL "
I can show you a dyno of two h series both 12.1 compression ,both head poerted by my dad ,both 88mm pistons ,Mine has a h23 crank (95mm), The other has a h22 crank (90mm). Both rmf replica header similar exhaust and intake . The only major difference is the 90mm stroke was h2b and the 95mm stroke was strait h which might make a small difference because of the gearing . My motor made 252 hp 182 tourqe ,His motor made 251hp 173 tourqe very close . The smaller stroke peaked about 500hp higher (it also had alot lower geared tranny ).
The kicker is the 95mm stroke made almost 20 more hp over the power band and ran half a second faster in a car that weighed 500 pounds more .
Both had pro 2 cams also. Unless you built two motors to test you couldnt get any closer then these two were . Ill try to post the dyno later. I actually had my tunner over lay my dyno on his just to see the difference when we had it tunned so i have a dyno graph to prove this.
Too many variables to compare....A dyno is a lot simpler.
me? yes i do. but there are too many variables involved in the comparison of them we need both engines assembled pretty much at the same time with the exact same everything, preferably with a stock heads or both ported and seeing a flow bench and flowing exactly the same
