engine overheating FAST
Old Mar 16, 2010 | 04:22 AM
integra_101's Avatar
Default engine overheating FAST
So we got the b18b1 engine in my DA. when i 1st started it, it filled my garage with smoke. smelt like burning gas. Im assuming thats the exhaust. no biggie.(not thick white smoke)
what im worried about is the engine, it was smoking when i came back from a drive. all the coolant lines are attatched and the rad is topped off. It looked like the smoke was coming from the bottom if the headers.
I didnt have the valve cover tight, just hand tightened. and oil was leaking from it.
Also my temp gauge was at half from only driving it for 2min
any help.
Old Mar 16, 2010 | 04:28 AM
wastedyouth2542's Avatar
Default Re: engine overheating FAST
if you valve cover was loose oil probably just dripped on your header. did you check your thermostat?
Old Mar 16, 2010 | 04:51 AM
I didnt. Ill ask the guy i bought the engine off of. Hes truthful with me
Old Mar 16, 2010 | 05:26 AM
if you dont know when it was chnged last and you car is over heating i would just change it anyway, i think its only like 10 bucks at autozone. then i would flush your coolant and put all new in, maybe something is just plugged up
Old Mar 16, 2010 | 05:34 AM
I just installed a new rad when i put the engine in on sunday and new fluid. Ill check for any plugs or kinks. My lower rad hoses and **** is all rotted
Old Mar 16, 2010 | 06:07 AM
Acuronda_SloTeg's Avatar
dumb question but did you bleed the coolin system correctly? lol
Old Mar 16, 2010 | 06:19 AM
How would I do that. and i think we did. Because we swapped the engine and the rad.
Old Mar 16, 2010 | 06:22 AM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-eg-b16-swap-problems-2743700/
anyone can criticize my method of bleeding the system, my homeboy has been workin at acura for over 8 years and uses the exact same method
Old Mar 16, 2010 | 09:39 AM
TheAsian's Avatar
Originally Posted by Acuronda_SloTeg
https://honda-tech.com/forums/showthread.php?t=2743700
Thats how I do it. Never had any issues. Bleeding is easy but people always make it so complicated.
johnca
Mar 22, 2006 12:32 PM
McNizzle
Jan 31, 2005 03:14 PM
ScubaStevo80
Jan 2, 2005 11:17 AM
sutekidane
Oct 27, 2003 08:58 AM
Cyber ITR
Jun 9, 2002 05:28 AM
