engine sleeve questions and pistons
i want to resleeve my motor. i got a b16 right now. should i resleeve the b16 or a b18a. these are my choices because the short blocks are pretty cheap. also i want to try to put out like high 300whp-400whp. should i get open deck sleeves or close deck sleeves. i want to bore the new sleeves so whats the max bore on a b16w/sleeves or a b18a with sleeves. if its the same i'd rather use b16 because b16's are earsier to find and cheaper. links comments anything.
bore is the same on both blocks. Max bore with turbo with sleeved block should be about 84mm. The ls block will give you more cc's because of the longer stroke. Either block should work good for you. The ls needs to be converted for vtec whereas the b16 should be ready to go.
We can sleeve your motor to accept 85 mm max turbo application. This block will be able to handle well over 800 h.p. and you can get all the components through us including pistons, rods, bearings, full build, etc. Give us a call (909) 592 - 4311 ext. 104. Thanks and hope we can help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">We can sleeve your motor to accept 85 mm max turbo application. This block will be able to handle well over 800 h.p. and you can get all the components through us including pistons, rods, bearings, full build, etc. Give us a call (909) 592 - 4311 ext. 104. Thanks and hope we can help!</TD></TR></TABLE>
Vince would you recommend going 85mm right away??? Ive never seen you post that before, is this because of your new sleeve design??
85 mm is the max for turbo, but if the motor is built properly in the first place then everything should be o.k. I love 85 mm turbo cars on the street, they really have some *****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">85 mm is the max for turbo, but if the motor is built properly in the first place then everything should be o.k. I love 85 mm turbo cars on the street, they really have some *****
what are good for the 01 USDM H22 motors?
what do u recomend?
sry to hijack your thread man.
</TD></TR></TABLE>what are good for the 01 USDM H22 motors?
what do u recomend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">H22 can go as big as 89 mm turbo, but the H22 has so much bottom end torque anyway that I like to stick around 88 mm or even stock! </TD></TR></TABLE>
okay thanks man!
okay thanks man!
Benson now has an 86mm Turbo Sleeve available for the B20 blocks. We will be running it next season on methanol. Early testing has shown that it will hold 1000 horsepower but we will detune from that number but the block itself held up great.
</TD></TR></TABLE>Benson now has an 86mm Turbo Sleeve available for the B20 blocks. We will be running it next season on methanol. Early testing has shown that it will hold 1000 horsepower but we will detune from that number but the block itself held up great.
Guest
Posts: n/a
i highly doubt that extra mm is worth it on the street...
</TD></TR></TABLE>i highly doubt that extra mm is worth it on the street...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
i highly doubt that extra mm is worth it on the street...</TD></TR></TABLE>Exactly right. It is possible, but not at all wise to run a turbo block over 84mm on the street. Poor advice for the nube and it proves nothing.
SpdFrk
Aug 29, 2003 07:42 AM
RICE POLICE SIP
Mar 26, 2003 07:41 PM
