Engine Noise: Pistons or valvetrain?
Old Jun 14, 2006 | 03:25 PM
.dave's Avatar
i HAS questions ?
Default Engine Noise: Pistons or valvetrain?
I finally got my car together and running, however there is noise coming from the engine bay. It sounds like a light ticking/knocking sound when the car is idling. When it first starts up, it is a little louder than if has been running for a few minutes, but not by much at all. You can still hear it inside the car when idling at a stoplight. I thought maybe the valve lash might need to be adjusted, so I did that today and the sound is still there. The car has a built D16Y8 including Crane valvesprings and titanium retainers as well as SRP pistons. I called Crane and they said that they had not heard of anyone having an issue with a noisy valvetrain. Anyone have a clue?
Old Jun 14, 2006 | 04:05 PM
TypeSLO's Avatar
Default Re: Engine Noise: Pistons or valvetrain? (daveG)
ticking and knocking are a world apart. i don't know if anyone can help you without actually hearing it themselves. take it to a reputable shop and ask for them to diagnose it.
Old Jun 14, 2006 | 04:12 PM
alpha's Avatar
Default Re: Engine Noise: Pistons or valvetrain? (TypeSLO)
Yup. Can you post a good/clear video?
Old Jun 14, 2006 | 04:17 PM
QwkD16's Avatar
The SRP pistons are where you are hearing the noise. I have the same problem. The pistons are a little loose. If the stock bore is what you are running, then the SRP pistons are smaller by a few thousandths. It wont hurt anything as long as you dont push it until it is warmed up. Loose is actually better for power.
Old Jun 14, 2006 | 04:35 PM
Muckman's Avatar
Moderator in Chief
Injectors?
Old Jun 14, 2006 | 05:34 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">I finally got my car together and running, however there is noise coming from the engine bay. It sounds like a light ticking/knocking sound when the car is idling. When it first starts up, it is a little louder than if has been running for a few minutes, but not by much at all. You can still hear it inside the car when idling at a stoplight. I thought maybe the valve lash might need to be adjusted, so I did that today and the sound is still there. The car has a built D16Y8 including Crane valvesprings and titanium retainers as well as SRP pistons. I called Crane and they said that they had not heard of anyone having an issue with a noisy valvetrain. Anyone have a clue?</TD></TR></TABLE>
What cam?
Old Jun 14, 2006 | 05:46 PM
.dave's Avatar
i HAS questions ?
Default Re: Engine Noise: Pistons or valvetrain? (Muckman)
I'll try and get a video up tomorrow maybe, its somewhere packed up with all my **** from school. I listened to the engine through the valve cover with a beer bottle (ghetto, but you can hear things really well) and the louder tick/knock didn't sound like the valvetrain at all.
Old Jun 14, 2006 | 05:47 PM
.dave's Avatar
i HAS questions ?
Default Re: Engine Noise: Pistons or valvetrain? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">What cam?</TD></TR></TABLE>
Crane stage 1 (street/turbo cam).
Old Jun 14, 2006 | 05:55 PM
iBrandon's Avatar
Do a valve adjustment...be sure ur timing is sync to stock settings...also it could be ur injectors ticking very loud as well
Old Jun 14, 2006 | 07:29 PM
.dave's Avatar
i HAS questions ?
Default Re: Engine Noise: Pistons or valvetrain? (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">Do a valve adjustment...be sure ur timing is sync to stock settings...also it could be ur injectors ticking very loud as well</TD></TR></TABLE>
Valves were adjusted today, as I said in my first post. Timing is also sync'ed up, the car runs great, theres just some noise from the engine bay.
Injectors are RC550's, Peak/hold run through a resistor box. Are these known for being loud (or at least considerably louder than stock injectors)?
Old Jun 14, 2006 | 07:32 PM
Zakar's Avatar
who built the bottom end?
Old Jun 14, 2006 | 08:03 PM
TypeSLO's Avatar
Default Re: (Zakar)
when you did the valve lash, did you do it with the motor cold or warm? did you go over them after you set it? it's such a pain in the *** but you have to check.
Old Jun 14, 2006 | 08:09 PM
oscarmayer's Avatar
rather than taking a chance in a built motor, take it to a shop, serously, do you want to chance if there is something wrong ruining an expensive motor?
Old Jun 14, 2006 | 10:39 PM
sohc_turd's Avatar
Default Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">rather than taking a chance in a built motor, take it to a shop, serously, do you want to chance if there is something wrong ruining an expensive motor?</TD></TR></TABLE>
Taking it to a shop dosn't gaurantee anything.
Does the noise go away or lighten up when warm?
Old Jun 15, 2006 | 02:55 AM
.dave's Avatar
i HAS questions ?
Default Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar &raquo;</TD></TR><TR><TD CLASS="quote">who built the bottom end?</TD></TR></TABLE>
A local shop that is very well known in the V8 world built the bottom end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSLO &raquo;</TD></TR><TR><TD CLASS="quote">when you did the valve lash, did you do it with the motor cold or warm? did you go over them after you set it? it's such a pain in the *** but you have to check.</TD></TR></TABLE>
Yes, it was done with the engine cold and I checked it again after I was done.
Old Jun 15, 2006 | 03:57 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
from my experience, shops well know to the V8 worl dont take into consideration that honda clearances are 10 thousandths of an inch, where most v8's are thousandths of an inch, so when they just "glance" at the clearance say .0016" they read it as 16 1,000ths when actually it is 16 10,000ths, 16 1,000ths = 160 10,000ths
Old Jun 15, 2006 | 06:09 AM
.dave's Avatar
i HAS questions ?
Default Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">from my experience, shops well know to the V8 worl dont take into consideration that honda clearances are 10 thousandths of an inch, where most v8's are thousandths of an inch, so when they just "glance" at the clearance say .0016" they read it as 16 1,000ths when actually it is 16 10,000ths, 16 1,000ths = 160 10,000ths</TD></TR></TABLE>
I trust that the engine builder got the clearances correct as he has done work with Honda engines before, and wouldn't just "glance" at the clearances.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_turd &raquo;</TD></TR><TR><TD CLASS="quote">Does the noise go away or lighten up when warm? </TD></TR></TABLE>
Driving to work today I did notice that the volume of the noise was consistent regardless of RPM or time running, though it did increase with speed.
GreddySi99
Sep 27, 2003 10:38 AM
Hybrid
Jan 9, 2003 08:00 PM
GruvyTune
Aug 30, 2002 12:54 AM
turboex
Apr 8, 2002 01:37 PM
Trajic
Nov 15, 2001 05:08 AM
