engine dies after boost....
Old Apr 26, 2010 | 06:17 PM
azandford's Avatar
Default engine dies after boost....
i jus had my b16a2 in my 98 ek built and i picked it up today..
sometimes after banging it out to 8k it will just die and other times it wont
i have cleaned my iacv... any ideas on what i should check?
Old Apr 26, 2010 | 08:24 PM
Adam_b16a's Avatar
Default Re: engine dies after boost....
Is it tuned?
Old Apr 26, 2010 | 08:26 PM
azandford's Avatar
bump i pulled in 4th and then throw it into neutrala nd the rpms would go down til it dies
azandford's Avatar
tuned with hondata s300
Old Apr 26, 2010 | 08:30 PM
builthatch's Avatar
MiG-21 superfan
here's a real zinger for you.
first let me ask, what kind of fuel pressure regulator? depending on your answer, i can actually go somewhere with that...
also, who tuned the damn thing? sounds like something is going on in high vacuum, ie massive fuel dump right before it "dies".
Old Apr 26, 2010 | 08:32 PM
azandford's Avatar
stock FPR tuned by the shop who built my engine it was doing this before the engine was built though my last setup had busted 3 rings so i figured it was ring related but it doesn appear that way now
runnning 750 cc injector dynamic injectors makin 275 hp on 11 psi
Old Apr 26, 2010 | 08:37 PM
azandford's Avatar
the afr stays pretty consistent all the way up to 8k on my dyno sheet right in between 11.3 and 11.5
Old Apr 26, 2010 | 08:38 PM
builthatch's Avatar
MiG-21 superfan
sounds crazy but take the vac hose off of the FPR at idle and suck on it. if you taste fuel, you have a ripped diaphragm. under vac it's sucking fuel through the FPR vac line and subsequently dumping that fuel into the cylinders with no load, making for a super rich condition that kills the spark.
it's a shot in the dark, but i've seen it happen before.
Old Apr 26, 2010 | 08:59 PM
azandford's Avatar
Thanks. I will definitely Check that in the morning. Would that account for the intermittent problem? Any other suggestions see appreciated.
Old Apr 26, 2010 | 11:54 PM
cleansi's Avatar
you should deff crank your fuel pressure up tp 55 psi invest any ways in a new regulator.
Old Apr 27, 2010 | 09:06 AM
azandford's Avatar
my tuner said we might need to raise the iac duty cycle... sound like that could be the problem?
Old Apr 28, 2010 | 06:09 AM
azandford's Avatar
FRP seems top be ok, i sucked on the hose ( that was fun...not ) i also have an fuel pressure guage and it seems to be pretty normal
could it be a busted up IACV? my idle seems to dip a bit low and then correct itself when putting into neutral at any speed/rpm
Old Apr 28, 2010 | 06:10 AM
azandford's Avatar
do i need to retune when adding the new FRP? also is there a suggestion on a decently priced one?
Old Apr 28, 2010 | 07:42 AM
dpetro1's Avatar
this sounds like the most logical explaination to me. start with that before you go tossing new parts at it. do you have a laptop? you can go in an change it yourself in like .2 seconds
Old Apr 28, 2010 | 11:34 AM
azandford's Avatar
yea i have a laptop but i dont know anything about s-manage... IS it possible that the iacv might be trashed?
everytime i unplug it while at idle the engine just dies... thats not normal is it? i thought it was suppose to raise the idle if it was working when i unplugged it
Old Apr 28, 2010 | 12:39 PM
dpetro1's Avatar
the idle should drop to about 4-500 rpm when the iacv is unplugged. you should set the base idle using the idle screw on the tb (jump service connector, turn off all accessories). then plug in your iacv and clear the CEL, you should be at 750 or whatever your s300 is set at.
as far as s-manager just download the software on your laptop, open it up and start getting familiar. follow the instructions for installing the drivers (windows should do it automatically). then ask the tuner to provide you with the tune file. open your tune, go into idle speed tab and raise the iacv duty cycle. upload the changes and you are done.
if you dont feel confortable, im sure your tuner will take care of you.
Old Apr 28, 2010 | 12:47 PM
azandford's Avatar
but every time i unplug the iacv it just dies... is it a bad iacv?
Old Apr 28, 2010 | 12:58 PM
dpetro1's Avatar
no this is a sign that your iacv is working but your base idle is set too low. thats why i suggest first increasing idle via the idle screw with the iacv unplugged. then adjust the iacv duty cycle via smanager if needed
playahwitgame
Jul 1, 2006 06:45 AM
B20luda
Jun 20, 2005 06:02 PM
mafay2
Jan 29, 2005 11:36 AM
freeplay
Nov 2, 2002 01:28 PM
93LSivic
Apr 8, 2002 10:31 PM
