Engine dies
Old Oct 22, 2005 | 10:59 AM
Shmaa's Avatar
Default Engine dies
A while back I swapped in 750cc injectors, walbro 255lph pump, and a new Hondata s300.
Now anytime I go to fill up with gas, if I have the car runing while the turno timer is counting down and I take the gas cap off the car dies...To me this just sounds like its losing too much fuel pressure, but I know with the stock injectors and pump it could idle without the gas cap on. Is that normal?
And another thing is when I go to start the car after i get gas. It Won't start unless i give it gas and I have to stay on the gas a little bit for about a minute before it will hold an idle. Changing the cranking fuel trim or post start fuel adjustment does not affect this problem. Only does this the first start after getting gas.
Are there any possible problems here? FPR dying? or is this just a normal thing with large injectors?
Old Oct 23, 2005 | 07:03 PM
Shmaa's Avatar
Default Re: Engine dies (Shmaa)
Old Oct 23, 2005 | 07:55 PM
krazn's Avatar
who tuned the car?
Old Oct 24, 2005 | 08:11 PM
Shmaa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazn &raquo;</TD></TR><TR><TD CLASS="quote">who tuned the car? </TD></TR></TABLE>
Car has a good tune and I am lead to believe this is not a tuning issue. This ONLY happens the first statup after getting gas. Any other time the car starts flawlessly
Old Oct 25, 2005 | 07:02 PM
Shmaa's Avatar
It turned out to be the EVAP purge solenoid. Thanks ginoboy1978 . All I did was unplug it and all is good now. Guess OBD-II EVAP's dont like OBD-I ecu's
RomesEM1
Feb 10, 2010 02:18 PM
sevenfc
Jul 12, 2009 11:56 PM
igo4bmx
May 20, 2005 12:58 PM
sik_sol
Apr 7, 2005 07:14 PM
Sergei01
Apr 12, 2004 11:30 PM
