did compression test...now car wont spark/start
Old 10-10-2005, 09:23 AM
DriveSlowHomie's Avatar
Default did compression test...now car wont spark/start
did a compression test yesturday and after that the spark plugs are not sparking...i pulled the ecu fuse when i was doing the compression test...the injectors are still spraying fuel, but the injectors just wont spark...what can cause this?...is it most like the coil or the module?
Old 10-10-2005, 10:02 AM
BigDaddyRich's Avatar
Default Re: did compression test...now car wont spark/start (cmGSR916)
Check the AC/IGN fuse under the dash. Did you reconnect the wires to dizzy or other things u disconnected?
Old 10-10-2005, 08:35 PM
Default Re: did compression test...now car wont spark/start (BigDaddyRich)
i never took off the wires to the dizzy...yes i did reconnect the ecu fuse i took out...the ac/ig fuse is still good...any other suggestions
Old 10-10-2005, 10:01 PM
LVB18Civic's Avatar
Check your coil and Ignitor.
Old 10-10-2005, 10:21 PM
ccfab's Avatar
Default Re: did compression test...now car wont spark/start (LVB18Civic)
its def your coil, replace it with a known good one and roll.
Old 10-11-2005, 08:07 AM
Default Re: did compression test...now car wont spark/start (ccfab)
any other coil will fit correct?...like from a sohc dizzy?
Old 10-11-2005, 08:25 AM
98coupe's Avatar
Location: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Just had the same thing happen to me did not take off the wires at the dist. Then no spark when trying to start car. Checked all the fuses replaced dist cap and rotor. Checked current going to dist all was good finally went to Advanced Auto got a new coil and it fired up.
Old 10-11-2005, 08:52 AM
Default Re: did compression test...now car wont spark/start (98coupe)
why would u have to take the plug wires off the dizzy when doing a compression test?...its not connected on the other side anyways correct?...i dont get this
Old 10-11-2005, 10:47 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmGSR916 &raquo;</TD></TR><TR><TD CLASS="quote">why would u have to take the plug wires off the dizzy when doing a compression test?...its not connected on the other side anyways correct?...i dont get this</TD></TR></TABLE>
You don't. Are you 100% sure you're not getting spark? And it's all 4 cylinders? Are you 100% sure your injectors are firing? If that's the case and you went over all applicable fuses, then yea I'd suggest replacing the coil, and yes all B and D series coils work.
Old 10-11-2005, 11:37 AM
Default Re: did compression test...now car wont spark/start (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">
You don't. Are you 100% sure you're not getting spark? And it's all 4 cylinders? Are you 100% sure your injectors are firing? If that's the case and you went over all applicable fuses, then yea I'd suggest replacing the coil, and yes all B and D series coils work.</TD></TR></TABLE>
thanks
Old 10-25-2005, 07:28 PM
okay used my buddys distributor and the car starts rite up...switched the coil on my old dizzy and tried it and the car wont start...so im thinking its the ignition module...can i get a sohc module and use it on my gsr dizzy?...having so many troubles on my car lately
njmad
03-25-2010 05:35 PM
eagle459
09-01-2008 03:06 PM
95teg_ls
04-21-2008 08:42 AM
steveo135
01-08-2008 06:55 PM
itr1235
05-30-2007 04:34 PM
Quick Reply: did compression test...now car wont spark/start
