Engine characteristic by design
Old Jun 25, 2003 | 11:08 PM
mgro's Avatar
Default Engine characteristic by design
I currently own a JRSC-ed B16. I like the engine characteristic of this combination, except for the low end torque. What I'm looking to achieve is a torque curve that extends significantly lower then the B16, without sacrificing top end (too much).
I am looking to build something around the Dart/Payn block casting (because its strong and an extended deck height version is available, allowing for a good R/S ratio). I will re-use the JRSC on that block (and the B16 head). Right now, I'm having trouble selecting the right stroke. I'm tempted to drop in a 95mm stroke crank for gobs of torque, but I'm afraid top end will suffer too much. The alternative is to drop in a GSR or B20 crank (87/89mm). Is there anyone here who has "been there, done that"? Dyno results would be great, as well as any opinions you may be willing to share!
Thanks,
Mark.
Old Jun 25, 2003 | 11:33 PM
MiraiZ's Avatar
Default Re: Engine characteristic by design (mgro)
people here don't like SC's too much...they are gonna tell you to go turbo and get a small turbo like a t3 or a T28 ....but I would never tell you to do that...
Old Jun 26, 2003 | 12:05 AM
lazerus's Avatar
Default Re: Engine characteristic by design (MiraiZ)
you want high compression, and biggest displacement for big low end...
Old Jun 26, 2003 | 06:49 AM
mgro's Avatar
<bump>
Jax99SI
16
Jul 9, 2008 08:46 PM
lcjarrett
May 17, 2005 01:38 PM
project dc2
Jul 27, 2004 06:43 AM
highschooler
Jun 20, 2002 06:09 PM
AfEn808
Dec 12, 2001 01:47 AM
