engine builders what micrometer u guys use ?
Old Apr 11, 2006 | 02:21 PM
EK FLY's Avatar
Default engine builders what micrometer u guys use ?
I'am in the prosses of installing my crank and I know what color I need so far (bearings) so i WAS JUST WONDERING WHAT kind of micrometer u guys using for a acurated reading ?
Old Apr 11, 2006 | 02:46 PM
simike's Avatar
Default Re: engine builders what micrometer u guys use ? (TURBO-WAWA)
An outside mic that reads down to the .0001".
Old Apr 11, 2006 | 02:50 PM
93LSivic's Avatar
Default Re: engine builders what micrometer u guys use ? (simike)
I use all Mitutoyo inside and outside mics. But as stated above just get one that goes down to .0001" and make sure you get a standard with it to make sure its calibrated properly.....although even if it isn't you can still get away with it since you use them to setup your bore gauge and it'll carry over.
Old Apr 11, 2006 | 04:26 PM
Ekasey's Avatar
Default Re: engine builders what micrometer u guys use ? (93LSivic)
Mitutoyo or sunnen
Old Apr 11, 2006 | 04:43 PM
ludesleep's Avatar
Default Re: engine builders what micrometer u guys use ? (Ekasey)
sunnen bore gauge and brown and sharp calipers
Old Apr 11, 2006 | 06:19 PM
nickromeo's Avatar
what u can do for measureing bearings is use a normal micrometer and on the concave part use a wire thread gauge, then measure youir reading, to the tenth, then subtract the size (diameter) of the wire thread gauge.
that way u dont need a special mic for reading a round convex part with a anvil that is not dome shaped.
sometimes u can get away with just the pointy part of a dial caliper.
bigsnorlax
47
Apr 1, 2011 02:06 PM
elpiar
Apr 5, 2005 10:59 PM
eg92b16a2
Welding / Fabrication
Oct 22, 2004 12:03 PM
CrazyModGSR
Audio / Security / Video
21
Jul 15, 2004 07:09 PM
BowSeR
Dec 15, 2001 12:51 PM
