When building your motors how many of you...
Re: When building your motors how many of you... (BowSeR)
there are various types of Micrometers. you have insude, outside, hole, etc. The inside micrometer can be used to determine things like Cylinder diameter and roundness. You can use the outside micrometer to check the diameter of crank bearing journals, rod bearing journals etc. Plastigauge is used to determine the amount of play or Clearnace that you have between the bearing and journal when everyting is torqued. hard to explain, but very important to use micrometers when building an engine.
D Tranny Guru
Re: When building your motors how many of you... (GruvyTune)
Then you'd better find some gauges.
You use a "inside gauge" and use the micrometer to read it.
That way you have no gauge to gauge variances.
Re: When building your motors how many of you... (drealgsr)
Here is a pic of me looking like an absolute dork measuring cyl #4 with a cylinder bore gauge. It is a spring loaded device designed to measure cylinder bores in all directions to determins taper, etc.
http://rely.net/~dustin/sema/IMG_1810.JPG
Re: When building your motors how many of you... (dustin)
Dustin,
to do a rebuild like that do you remove the head with the cams intact and slide the cam gears out from the timing belt leaving the belt in place? Is it a pain to get back in after?
Also, do you take out the oil pan to get to the rods in order to remove the pistons?
thanks
torin
thanks
torin
You have to remove the cams to remove the head bolts.
You have to remove the oil pan and windage tray to remove the nuts on the rod bolts and thus the rod caps.
Dustin
Dustin
Combustion Contraption
76
12-17-2008 09:09 AM
mister2racer
02-05-2007 08:45 AM
