Race engine. High or low compression recommended?
Old Aug 10, 2004 | 03:07 PM
flip1199's Avatar
Default Race engine. High or low compression recommended?
i've read all the threads about high and low compression on pump gas and all that. i'm talkin about a motor that will only be ran on race gas. since the motor is only gonna be run on race gas what limits higher compression 10:1+? what are the advantages and disadvantages of low compression (8.5:1 and lower) and higher compression (10:1 and higher) in race engine applications?
Old Aug 10, 2004 | 10:46 PM
flip1199's Avatar
Default Re: Race engine. High or low compression recommended? (flip1199)
ttt
Old Aug 11, 2004 | 12:10 AM
JDogg's Avatar
you need to figure out how much power you want, then figure out what gas you can run, then you can decide on compression.
personally i would go with a flat topped piston with as few "features" as possible. this will keep the heat more uniform across the top of hte piston and give the flame/mixture a smoother path. thats what i plan on doing in my race car.
depending on the head and chamber work that should get you around 9.5-10:1 compression. with that compression you can still run 350-400 on pump gas and have some fun on the street
Old Aug 11, 2004 | 12:16 AM
flip1199's Avatar
Default Re: Race engine. High or low compression recommended? (JDogg)
well this car will only see the track, so i'm not really worried about pump gas drivability..
Old Aug 11, 2004 | 12:42 AM
MiraiZ's Avatar
will you be rebuilding often?
Old Aug 11, 2004 | 01:01 AM
flip1199's Avatar
Default Re: Race engine. High or low compression recommended? (MiraiZ)
hopefully not, but probably if something breaks then i'll rebuild it..
Old Aug 11, 2004 | 02:20 AM
MiraiZ's Avatar
high compression, race gas, forged rods and pistons
Old Aug 11, 2004 | 02:33 AM
quik sol's Avatar
Wouldnt low low low compression be good for a FULL race motor? like 8.5:1 or even a 8.0:1? I thought people just didnt use those on street setups but it would be good for full-race because of the amount of boost it could take. Please correct me if I am wrong.
Old Aug 11, 2004 | 02:36 AM
MiraiZ's Avatar
Default Re: (quik sol)
low compression is the safer setup for street driven cars...If I were building a race car, I'd go 11:1 with 10-12psi on race gas
Old Aug 11, 2004 | 03:34 AM
JDogg's Avatar
Default Re: (MiraiZ)
you use compression to control the ammount of power you can make on a specific octane fuel.
i have done over 500 on 7.8:1 2liter b16 with pump gas, you cant go much over 375hp on pump gas with flat top'd 9.8ish:1 pistons in a b18.
compression dosnt really matter untill you start pushing the limits of your fuel. if you make 300hp on 10psi with 10:1 you will make 300hp on 10psi with 8:1. the difference comes in when you start adding boost. you can add alot more boost with 8:1 than you can 10:1 on said gas. the higher octane gas you use the higher that limit becomes.
Old Aug 11, 2004 | 08:05 AM
flip1199's Avatar
Default Re: (JDogg)
with 10:1 and c16 what are the limits???
Old Aug 11, 2004 | 09:35 AM
DLB1994's Avatar
Default Re: (flip1199)
it comes down to how much power you want and your max boost you can run and are running a 3bar map or 5 bar map?
Old Aug 11, 2004 | 11:49 AM
rmcdaniels's Avatar
Figure out what effective compression you are aiming for. Typically around 20:1 on pump gas with sleeves and forged internals, and probably not more than 22:1 on race gas.
The formula is:
((boost psi / 14.7) + 1) x static compression = effective compression
I run 22 pounds of boost with 8.4:1 static compression for 20.9:1 effective compression on a B16. That nets me 350-400WHP, depending on my turbo setup and tune (tuned by jdogg incidentally).
Generally speaking, the lower you go with your static compression, the more peak power you can make for a given effective compression, and the more off-boost performance you give up. So it's a balance between daily drivability and max power. If you're only going to be drag racing at the track, I'd say get your compression around 8:1 and turn up the boost until you hit 22:1 effective compression, with good tuning of course, otherwise you will just blow your stuff up.
Old Aug 11, 2004 | 11:52 AM
DIRep972's Avatar
Smarter than you
Default Re: Race engine. High or low compression recommended? (rmcdaniels)
I go back an forth even in my own brain on this debate. I used to be all about high compression, but recently ive changed my opinion. I don't want to be boost limited.
Old Aug 11, 2004 | 12:01 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">Wouldnt low low low compression be good for a FULL race motor? like 8.5:1 or even a 8.0:1? I thought people just didnt use those on street setups but it would be good for full-race because of the amount of boost it could take. Please correct me if I am wrong.</TD></TR></TABLE>
The reason people run low compression in street cars is because they are running pump gas and are worried about detonating on low octane. If you're running C16, who gives a **** about detonation, it's practically a non-issue with a fuel of that high octane. The higher compression will make a bit more power N/A, and then should make a little bit more power when boosted. I'd guess that going from 9:1 to 10:1 or even 10.5:1 might be worth 20 WHP on a 550-600 WHP setup.
Old Aug 11, 2004 | 12:16 PM
TrueNorthStar's Avatar
Default Re: (b16coupe)
You can run meth on 12/1 and loads of boost.... 900hp range
Old Aug 11, 2004 | 03:02 PM
flip1199's Avatar
[QUOTE=rmcdaniels]Figure out what effective compression you are aiming for. Typically around 20:1 on pump gas with sleeves and forged internals, and probably not more than 22:1 on race gas.
The formula is:
QUOTE]
well if i plug my current setup in that formula i can only boost 18lbs on race gas safely??? i'm currently running 10:1. what about all those other pro racers running 10:1-11:1 on race gas boosting 25-35lbs? how can they get away with it?
Old Aug 11, 2004 | 03:27 PM
95GSRTT
Guest
Posts: n/a
probably a better race gas than you.
Old Aug 11, 2004 | 08:10 PM
JDogg's Avatar
Default Re: Race engine. High or low compression recommended? (95GSRTT)
effective compression is an ok rule of thumb sometimes.... but its more to do w/power than boost. i have done a couple of single cams boosting over 20psi, but only making 300hp and still on pump gas...
spoonEGcivichatch
Sep 18, 2005 09:51 AM
blusmke
Sep 26, 2004 03:02 PM
GRTechnologies
Aug 11, 2003 07:20 AM
wickedEFguy
Feb 3, 2003 11:14 PM
BLITZ
Oct 29, 2002 07:59 PM
