engine anchoring/lift points???
Old Aug 11, 2002 | 06:53 PM
c1hatch's Avatar
Default engine anchoring/lift points???
just wondering what points everyone uses to lift the engine in/out of the car? i've always used the timing mount & the little bracket on the tranny, or a tranny bolt.
just curious as to where the proper points are...
Old Aug 11, 2002 | 07:43 PM
Brian_92GSR's Avatar
New User
Default Re: engine anchoring/lift points??? (c1hatch)
I'm not sure what timing mount point you are taking about - I use the tranny bracket and a bolt threaded into the head on the back driver side. That is the proper point on the drivers side.
Old Aug 11, 2002 | 08:11 PM
paulzy's Avatar
Default Re: engine anchoring/lift points??? (Brian_92GSR)
I use the same as Dee, plus teh other way around also(a bolt threaded to where the PS pump used to be)
Old Aug 11, 2002 | 10:13 PM
Flamenco-T's Avatar
Default Re: engine anchoring/lift points??? (Slow_ass_4dr)
I used one on the tranny by the slave cylinder and the back of the head on the driver side like Brian 92GS-R
just use4 regular ol 1000 lbs chain
Old Aug 11, 2002 | 10:17 PM
Kamin's Avatar
Default Re: engine anchoring/lift points??? (Flamenco-NA)
i use a starter bolt and the threaded hole on the drivers side.
Colt45DC
Apr 6, 2005 08:47 AM
743power
Jan 1, 2005 05:27 PM
ki11a8ee
Mar 12, 2004 05:51 PM
integraGSR213
Feb 16, 2004 11:19 AM
civickiller
10
Aug 12, 2003 12:44 PM
