Endyn catchcan install, whats this bracket in the way?
Old Aug 29, 2006 | 02:40 PM
KiddEng's Avatar
Default Endyn catchcan install, whats this bracket in the way?
There's this bracket that looks to be supporting the IM, and is in the way of me removing the black box in the back of block. All the pictures i seen on catchcan threads i never noticed this before.
i will have to take off this bracket in order to remove the box, but can i leave it off afterwards?
heres some pics of what im tlaking about:
Red dots are the bolts to remove the bracket for future reference
Heres how it blocks the box:
Old Aug 29, 2006 | 02:51 PM
mike93eh2's Avatar
yea leave it off if you have to... it will be fine.
Old Aug 29, 2006 | 03:25 PM
99B16Si's Avatar
take that sucker off. its just a brace. keep in mind theres a lot of places the wiring harness attaches to that thing too.
Old Aug 29, 2006 | 04:11 PM
Finland's Avatar
take the oem can off, cut the webbing off the bracket, otherwise you won't be able to get a nice routing of the hose accomplished
Old Aug 29, 2006 | 04:48 PM
KiddEng's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">yea leave it off if you have to... it will be fine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">take that sucker off. its just a brace. keep in mind theres a lot of places the wiring harness attaches to that thing too.</TD></TR></TABLE>
i'll double check before i fully remove the brace to make sure i got every clip and wire off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki &raquo;</TD></TR><TR><TD CLASS="quote">take the oem can off, cut the webbing off the bracket, otherwise you won't be able to get a nice routing of the hose accomplished</TD></TR></TABLE>
i'm just going to leave the bracket off, im lazy like that!
thanks for the replies, btw im going to use the rubber hoses for now, but later on can i use the clear braided hoses at Lowes/HomeDepot? or will those be too soft under heat? I got a hydraulic supply shop a lil further away, they will have the beefed up clear hoses.
Old Aug 29, 2006 | 06:30 PM
BoostedCivicSedan's Avatar
Default Re: Re: (KiddEng)
the rubber hoses that come with it are perfectly fine... Basically just like heater hose/ tranny cooler line type stuff... only "upgrade" would be like blue aeroquip hose or steel braided line or something along those lines...
Old Aug 29, 2006 | 07:22 PM
KiddEng's Avatar
Default Re: Re: (BoostedCivicSedan)
i know they will be fine... but i would like to see if im getting alot of oil through the lines or not, thats why the clear hose.
Old Aug 31, 2006 | 07:23 AM
99B16Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiddEng &raquo;</TD></TR><TR><TD CLASS="quote">i know they will be fine... but i would like to see if im getting alot of oil through the lines or not, thats why the clear hose. </TD></TR></TABLE>
wont be clear for long
Old Aug 31, 2006 | 08:22 AM
d357r0y's Avatar
The clear home store stuff wasn't made for oil or fuel and will colapse. Stick with the stuff the catch can came with.
BIG T
Jul 7, 2013 11:05 AM
X93siX
Aug 4, 2010 12:11 PM
dtrtw
Apr 5, 2005 08:54 PM
stevescivic
15
Jun 6, 2004 09:47 AM
