Antenna Question
Old Mar 19, 2008 | 08:54 AM
ImaHondaLover's Avatar
Default Antenna Question
Ok I just removed my whole antenna assembly, and yes it was necessary. I removed two things when i pulled off the motor, one is the connector to the antenna and the other looked like a vacuum line. My question is, is that really a vacuum line? and is it bad to leave it unplugged? Thanks in advance
Old Mar 19, 2008 | 09:30 AM
A's 94 GSR's Avatar
BG-33P
Default Re: Antenna Question (ImaHondaLover)
Pics?
Old Mar 19, 2008 | 09:42 AM
Dogginator's Avatar
Daisy... Daisy...
Plug that line, as it is a drain tube. If you leave it unplugged, the sunroof drain line will leak into the trunk.
Old Mar 19, 2008 | 07:23 PM
Default Re: Antenna Question (Dogginator)
Ok thanks man. I am gonna have to climb in there and find a way to plug it i guess. There is not good visibility since it is kinda behind the metal in the trunk you know? Any suggestions on what to plug it with ?
Old Mar 20, 2008 | 03:32 AM
Dogginator's Avatar
Daisy... Daisy...
You can go to a hardware store and find a fancy plug or just use a bolt covered with silicone gasket maker.
B_Swapped93
Feb 15, 2013 08:52 PM
brokenojoke
22
Apr 23, 2012 03:33 AM
importfanatic17
Apr 25, 2006 07:30 PM
xZeler8
Nov 10, 2004 06:46 PM
Batoutahell
Jul 6, 2003 01:39 PM
