Endyn catch can
Old Jul 18, 2007 | 12:52 PM
mahatma's Avatar
Default Endyn catch can
I've installed an Endyn breather/catch can on my LS, according to the instructions.
2 lines to each big block plug (left & right of the oil filter), drain t'd into 1 of them.
What do I do with the valve cover nipple (that went to the intake arm)?? Plug it?
Endyn has been helpful with tech support already, I'm just tired of pestering them now
Old Jul 18, 2007 | 01:03 PM
iBrandon's Avatar
Default Re: Endyn catch can (mahatma)
weld it off...or put a mini breather on it..
Old Jul 18, 2007 | 02:10 PM
SD_Lurker's Avatar
HT White Ops
if you look at the kit they also gave you something for the top of the can instead of the filter. you can run it that way or have another T
Old Jul 18, 2007 | 08:30 PM
Mr.Death's Avatar
The set up above would NOT work on a turbo application. The catch can located in front of the valve cover is ok but one near the firewall is not. While in boost the intake mani will pressurize the catch can and crankcase. Put a breather filter on the valve cover and run the 2 hoses from the back of the block to the can with a breather on top. Thats it thats all.
Old Jul 18, 2007 | 08:35 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">
don't plug it, leave it open.. and you don't need filter either. it will get clogged up
Old Jul 18, 2007 | 11:53 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">The set up above would NOT work on a turbo application. The catch can located in front of the valve cover is ok but one near the firewall is not. While in boost the intake mani will pressurize the catch can and crankcase. Put a breather filter on the valve cover and run the 2 hoses from the back of the block to the can with a breather on top. Thats it thats all.</TD></TR></TABLE>
Really? How is it possible that the intake manifold will pressurize the breather tank when the nipple you see on top of it has a check valve? Sorry but the picture wasn't working so I deleted it.
Old Jul 19, 2007 | 02:00 AM
methos713's Avatar
Default Re: (SD_Lurker)
for more info
Old Jul 19, 2007 | 05:51 AM
iBrandon's Avatar
Default Re: (methos713)
From my experience, if you use the pcv with the hose connected to that small nipple on the valve cover, the dam thing will pop off the catch can...better to use the filter and either plug or put a filter on the nipple..
Old Jul 19, 2007 | 06:01 AM
agrn93ls's Avatar
Default Re: (iBrandon)
my vote: put a filter on it.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
don't plug it, leave it open.. and you don't need filter either. it will get clogged up</TD></TR></TABLE>
i would never leave it open. thats like leavin the oil cap off almost why the hell would you leave anything on the engine open?
Old Jul 19, 2007 | 06:17 AM
mike1114's Avatar
Default Re: (agrn93ls)
Where's they chimp-like crayon drawings?
We can't have a catch can thread without someone going nut in MS Paint.
Old Jul 19, 2007 | 06:36 AM
agrn93ls's Avatar
Default Re: (mike1114)
lmao this is a first without.... be patient its coming.
Old Jul 19, 2007 | 06:57 AM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">lmao this is a first without.... be patient its coming.</TD></TR></TABLE>
....wait for it - wait for it.....
So.....cap it, vent it, or route it to the catch can?
Still a little confused.
Old Jul 19, 2007 | 08:10 AM
agrn93ls's Avatar
Default Re: (mahatma)
Still a little confused.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">my vote: put a filter on it.....
can be ran to another port on the can, sealed or filtered. i would put a filter since that is what the can is gonna do and youll have one less hose to deal with and any extra ventilation is good just not unfiltered. so there take that. jk
Old Jul 19, 2007 | 09:27 AM
street dream gsr's Avatar
* B A N N E D *
Default Re:
I used to run a little breather, but i ended up just running it open. my .2
T
Old Jul 19, 2007 | 09:30 AM
DaveF's Avatar
Default Re: Re: (street dream gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dream gsr &raquo;</TD></TR><TR><TD CLASS="quote">I used to run a little breather, but i ended up just running it open. my .2
T</TD></TR></TABLE>
Old Jul 19, 2007 | 10:24 AM
* B A N N E D *
Default Re: Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
wrong topic big guy.
Old Jul 19, 2007 | 12:29 PM
vtec.dc2's Avatar
i would never leave it open. thats like leaving the oil cap off almost why the hell would you leave anything on the engine open?
great argument.. maybe you should put a filter on exhaust.. thats like coming off the engine..
theres always pressure coming off when you don't have stock setup.. oil particles will still make their way through and that filter will get clogged, in that case, might as well weld that opening close.. i've been running like that for years and no problems, don't be suprised when you're having massive blowby due to lack of vents or worse. i have 3 vents on valve cover and no filters no catch cans, don't have any oil spills and no smoke out valve cover..
Old Jul 19, 2007 | 12:53 PM
agrn93ls's Avatar
Default Re: (vtec.dc2)
maybe we should put a filter on your mouth for that stupid comment. you know what i meant. i choose to run a 5$ filter that does not clog on my motor. but maybe i have less blow by. and you could just change it every once in a while or clean it too if its such a problem.
Old Jul 19, 2007 | 01:40 PM
vtec.dc2's Avatar
maybe we should put a filter on your mouth for that stupid comment. you know what i meant. i choose to run a 5$ filter that does not clog on my motor. but maybe i have less blow by. and you could just change it every once in a while or clean it too if its such a problem.</TD></TR></TABLE>
my whole point is.. gasses are exiting at all times from valve cover so what is there to filter?? filter doens't allow for more flow out the engine, you need to relief more pressure when making more hp, so filter, lines, and catch cans are just more restrictions if you can avoid it you're better of. most obvious thoughts would tell to put a filter on there, but i speak from experience and they don't do ****.
christmastree
Jan 27, 2012 06:07 AM
ToeJam
Feb 17, 2007 05:44 AM
digital sol
Aug 22, 2005 09:47 PM
Prelude91siT
Jan 1, 2004 10:42 AM
Sinner
Jun 11, 2003 03:23 AM
