Emissions and turbo
Old Aug 5, 2003 | 08:17 AM
Odessa's Avatar
Default Emissions and turbo
Can someone tell me if emissions suck on a turbo car? How do those emissions tests like turbos?
Old Aug 5, 2003 | 10:48 AM
psileepR's Avatar
New User
Default Re: Emissions and turbo (Odessa)
emissions can be within limits with a turbo if tuned well.
I dont know if u are in the states or canada but over here in the US emissions testing is done at part throttle at 15 and 25mph so you are not in boost.
smog places that follow the rules frown on non carb legal turbo kits here in CA .
Old Aug 5, 2003 | 11:01 AM
boosted92's Avatar
Default Re: Emissions and turbo (psileepR)
If you were borderline passing before, good luck passing now. Turbo housing and exhaust wheel absorbs a lot of heat, that's what powers the turbo. Heat is needed for the cats to work, I think you know where i'm going. If you have proper fuel management it shouldn't be a problem though.
Old Aug 5, 2003 | 01:44 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Emissions and turbo (boosted92)
I have a test pipe, stinks like hell. But there are no emissions checks in Michigan! You're in Ontario, that's not too far away. Move down here.
But yeah, what everbody has already said is true.
Old Aug 6, 2003 | 06:59 AM
Odessa's Avatar
Default Re: Emissions and turbo (Snafu-Si)
Thank you for the offer to move to the States, but I'd rather stay here
From what I understood, the only reason not to pass an emission test with turbo is if something is wrong with your car/install/tuning. So I guess I should be ok if I go turbo...
Driven2Redline
May 8, 2009 09:00 AM
portaman03
Honda Civic (2001 - 2005)
10
Apr 30, 2007 08:08 PM
alacard
Jan 8, 2006 08:52 AM
SPOONup
Jan 7, 2005 12:18 AM
2k2civic
Jan 16, 2002 12:29 PM
