EGT Temps
Old Jun 3, 2004 | 12:43 PM
Soon_2b_evil's Avatar
Default EGT Temps
ok on a turbo honda what are the common EGT temps? How hot can it get?
How hot can a Exhaust manifold get?
when does stuff start to melt?
I wanna find out when because im trying to get my exhuast manifold, exhuast housing coated and im just trying to find the coat i would like.
I know jet-hot has a 2000coating and thats to about 2500degress but i dont think i need anything like that.
Thanks in advice.
Old Jun 3, 2004 | 01:15 PM
MachAF's Avatar
Default Re: EGT Temps (Soon_2b_evil)
Just go with a 2000 degree coating.
Old Jun 3, 2004 | 01:19 PM
Vtec92Civic's Avatar
Default Re: EGT Temps (MachAF)
yeah if your egt's get to 2,000 degrees you're motor will be melted so don't worry you prob. won't exceed mid 1400's ona boosted car.
Old Jun 3, 2004 | 01:20 PM
2000GSRT's Avatar
My EGT probe is mounted on the downpipe right after the turbo. I have never seen it go past 1400.
Old Jun 3, 2004 | 02:46 PM
Finland's Avatar
peak boost and rpm it flirts with 1500F on mine. My thermocouple is about 2" on the primary on cyl 1
Old Jun 3, 2004 | 03:18 PM
spoolinlude's Avatar
I live under a rock
Default Re: EGT Temps (boost psycho)
mine stands on 1600 every now and again, i think i have a faulty gauge though
Old Jun 3, 2004 | 04:53 PM
Jared's Avatar
Default Re: EGT Temps (spoolinlude)
mine is on #3(the hot cyl) and is about .75" from the head and i like to see 1450 going through the traps. 2000 deg will be fine.
Old Jun 3, 2004 | 04:58 PM
Default Re: EGT Temps (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">mine is on #3(the hot cyl) and is about .75" from the head and i like to see 1450 going through the traps. 2000 deg will be fine.</TD></TR></TABLE>
so i should run the jet-hot 2000coating?
ive found a place local that coats but its about 1800degress tho.
now if i was to run 13psi would my egt even get that high with 10.5:1compression?
i would most likly run 25psi at the track.
slim9300's Avatar
Default Re: EGT Temps (2000GSRT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">My EGT probe is mounted on the downpipe right after the turbo. I have never seen it go past 1400. </TD></TR></TABLE>
That doesn't seem like a very good place to take an accurate temperature reading. I was told this was ideal:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">mine is on #3(the hot cyl) and is about .75" from the head</TD></TR></TABLE>
Old Jun 3, 2004 | 05:08 PM
kpt4321's Avatar
Yeah, you'll probably see around 1600*F peak in the exhaust manifold.
Note the key words: Probably, around, peak.
Old Jun 3, 2004 | 06:09 PM
2000GSRT's Avatar
Default Re: EGT Temps (slim9300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">
I just followed the directions that came with the autometer guage. Plus, if it were mounted in the exhaust manifold and the probe broke and snapped off for any reason it could damage the turbo.
Old Jun 3, 2004 | 06:55 PM
ok. Yeha i know the EGT probe should be at Cly3.
ok Arounf 1600 is still decent. The coating like i said is about 1800degress so its still holding up.
Old Jun 3, 2004 | 07:43 PM
slim9300's Avatar
I think that running 1500-1600 degrees would be very dangerous for pump gas. I don't think you will be exceeding 1450 degrees. So the 1800 degree coating should be fine.
Old Jun 4, 2004 | 04:33 AM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">I think that running 1500-1600 degrees would be very dangerous for pump gas.</TD></TR></TABLE>
Why is a certain temperature dangerous? Basing engine safety on EGT is so stupid.
You can run really conservative timing advance (very safe) and it will jack your EGT's way up. Then if you advance the timing more (more dangerous), your EGT's will go down.
That's not helpful at all.
Old Jun 4, 2004 | 05:36 AM
2000GSRT's Avatar
Default Re: EGT Temps (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
That's not helpful at all.</TD></TR></TABLE>
so what would you say EGT is a good measure of?
Old Jun 4, 2004 | 09:26 AM
kpt4321's Avatar
It does a great job telling you what the temperature of the gasses leaving your motor are.
Old Jun 4, 2004 | 09:39 AM
Default Re: (kpt4321)
ok so about 1450 should be safe?
now when does stuff start to blow up and melt?
Old Jun 4, 2004 | 09:49 AM
Importracer_001's Avatar
I would also like to know this
I have a EGT probe on teh 3rd cilinder 2" from the head I'm getting about 1450 degrees when I go on the 1/4 mile and when I drive on the highway my EGT reads 1300 degrees F
Old Jun 4, 2004 | 09:51 AM
Default Re: (Importracer_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importracer_001 &raquo;</TD></TR><TR><TD CLASS="quote">I would also like to know this
Thanks for the info.
What is your setup if you dont mind me asking?
Old Jun 4, 2004 | 09:56 AM
kpt4321's Avatar
Stuff starts to emtl when bad things happen, there is no certain EGT where parts will melt.
2000GSRT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">It does a great job telling you what the temperature of the gasses leaving your motor are.
I was trying to get your opinion on why you think an EGT guage is important. Since you do not believe that it is an indicator of engine safety, what do you think EGT's indicate?
Old Jun 4, 2004 | 10:06 AM
kpt4321's Avatar
Default Re: (2000GSRT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">
I was trying to get your opinion on why you think an EGT guage is important. Since you do not believe that it is an indicator of engine safety, what do you think EGT's indicate?</TD></TR></TABLE>
Told told you already, I think EGT's indicate the averge kinetic eneregy (temperature) of the exhaust molecules leaving the motor.
It's a moderately decent tuning reference, but only if you have the rest of the proper equipment (wideband, possibly knock detection, etc).
It can NOT be used by itself.
Old Jun 4, 2004 | 10:14 AM
underpressure02's Avatar
My egt crusing on the highway in 5th at about 80 with a gsr tranny is around 650-700 degrees C. When I am on it hard the hottest I ever hit was 800 degrees C. Mine is mounted on my manifold in the #3 cylinder.
Old Jun 4, 2004 | 10:25 AM
PM-Performance's Avatar
Default Re: EGT Temps (underpressure02)
mine is usually like 1200 or so on the highway just cruising. and on the streets maybe like 800-1000
Old Jun 4, 2004 | 10:54 AM
hypa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">mine stands on 1600 every now and again, i think i have a faulty gauge though</TD></TR></TABLE>
I think your guage is working fine.
I know mine hits 1600 quite often, but I'm not worried at all since everytime I check the plugs, they look awesome, and every few months when I tear down the motor, the internals look good.
I hit 800 at idle, up to around 1200 at part throttle, and peak at about 1600 at WOT in the 1/4 mile.
