EGT reading question?
Old Jun 30, 2002 | 09:43 AM
fast[R]'s Avatar
Default EGT reading question?
OK guys the EGT probe is right next to the turbo on the down pipe, what temp should it read duing 100km? the car is not lean stock exost for now, and wen I get my full 3" exost will the temp drop?
Old Jun 30, 2002 | 11:15 AM
HXMan's Avatar
Default Re: EGT reading question? (fast[R])
I have heard from people on here that your exhuast temps will drop with a full 3" exhuast.
Old Jun 30, 2002 | 03:32 PM
Tuan's Avatar
Default Re: EGT reading question? (HXMan)
what are you reading right now? I'm interested to find out also!!!
Old Jun 30, 2002 | 10:30 PM
rice4life's Avatar
Default Re: EGT reading question? (roku21)
mine reads about 1100 deg. F. at 60mph and 1200 F. at 70 mph. the sensor is mouted on cylinder #3 about 1.5 inche from the head. my apexi a/r reads 16-17 at cruising but i think it's wrong because my 02 is none heated and it's mounted behind the turbo, so the reading might be off.
Old Jul 1, 2002 | 09:08 AM
fast[R]'s Avatar
Default Re: EGT reading question? (rice4life)
Mine is reading 1200 at 100 km, the probe is on the down pipe right by the turbo I think its a bit to hot my turbo is a t3/t4 it should bee reading a lil lower, but it could bee my stock exost
Old Jul 2, 2002 | 03:40 PM
fast[R]'s Avatar
No one elce!!!!
Old Jul 3, 2002 | 02:43 PM
fast[R]'s Avatar
ttt
Old Jul 3, 2002 | 10:10 PM
SpeedRacer00-667's Avatar
between 1200 & 1300 f crusing at 75mph, the probe is about 3 inches down from the turbo
Old Jul 4, 2002 | 01:18 AM
shadowdawn's Avatar
Default Re: EGT reading question? (SpeedRacer00-667)
Mines in the downpipe flange attached to the turbo, it reads 710c in slight boost in 4th gear, but other then that it usually hits around 8 in mid boost, and in full boost in lower gears its 810-840c, The highest I ever got was doing 3rd gear to redline (NOT BOOSTING, JUST SLOWLY PULLING TO REDLINE TO TEST 3rd GEARS MAX MPH) it crept up near 850....
Also one time racing some gay riced accord on the highway it almost reached 900c.... I know that isen't good so I slowed down... My car needs some bigger injectors and tuning.. which is what I'm working on
Old Jul 4, 2002 | 02:03 AM
b18bvudoo's Avatar
New User
mine reads ~730 C cruising at 80mph. i'm running a bit rich tho. my probe is ~1.2 in. from the head
Old Jul 4, 2002 | 02:37 AM
boostinb18's Avatar
Default Re: EGT reading question? (vudoo666)
ok newb question.............where is the correct spot for the egt sensor??? and isnt this one of the best ways to accuratly reading air/fuel ratio???? if ist rich will it be hottter or cooler???
thanks!
[Modified by boostinb18, 11:37 AM 7/4/2002]
Old Jul 4, 2002 | 06:45 AM
rice4life's Avatar
Default Re: EGT reading question? (boostinb18)
you should mount the sensor on the turbo manifold about 1.5 inche from the head. cylinder #3 usually run the hottest. it should read hot when running lean and cold when rich if you mount the sensor right. if you mount the sensor on the down pipe too far from the head, it could read hot when you run too rich because the left over fuel burns in the turbo, so you would think that it was running lean.
speedymon's Avatar
Closer to the head the probe is the better. If you run lean your readings will be hotter and vise versa.
Old Jul 4, 2002 | 02:18 PM
fast[R]'s Avatar
So that's why I'm runing hot,too much fuel going into the turbo I know i'm not runing lean,right now i'm driving like an old lady on the high way. What is a normal temp. with a tooned motor and 3" exost. I'm planing to keep the probe on the same spot is it bad?
DukeCityEF
Jan 7, 2008 12:28 PM
WhoDoYouThink
May 19, 2005 04:13 AM
CivicEJ1
Dec 8, 2004 06:54 PM
Terrabomb
Jul 13, 2004 06:28 AM
Canuk_SiR
May 18, 2003 08:38 PM
