EGT probe tap and information.
Old Jun 1, 2004 | 01:52 PM
Blindstuff's Avatar
Default EGT probe tap and information.
I'm installing my EGT sensor in a couple of days. Now i've understood that its suposed to be #3 Cilinder since it gets the hottest, BUT, autometers probe instructions say if car is turbo mount after the turbo.
What should i do?
Also, what would be the normal ranges for EGT temp for my fuel ratio. When does temp go up (lean, rich). Honestlly i dont know how to read it well but i was told it was better than a A/F gauge and since my Turbo timer has that i decided to buy the EGT.
Thanx in advance
Old Jun 1, 2004 | 03:51 PM
pb16b's Avatar
Default Re: EGT probe tap and information. (Blindstuff)
usually you'd tap the egt probe onto the header close to the cylinder head. since you're running a turbo, it makes sense to tap it after the turbo on the downpipe somewhere. when you run lean, it will get hotter. rich will run cooler.
Old Jun 1, 2004 | 03:55 PM
DaX's Avatar
DaX
Loved
Community Favorite
It is best to tap about 3" from the head on the #3 runner, from what I understand. This is the hottest cylinder, and is the lead indicator if something is going wrong EGT-wise.
Old Jun 1, 2004 | 06:00 PM
Sketch_hs's Avatar
Default Re: (DaX)
why is 3 the hottest one?
Old Jun 1, 2004 | 07:51 PM
Blindstuff's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX from other thread &raquo;</TD></TR><TR><TD CLASS="quote">Because of firing order and the fact that it's between two cylinders...if you look at the firing order, it has an ignition cycle on each side back to back [or something along those lines] making it slightly hotter than the other three.</TD></TR></TABLE>
Old Jun 1, 2004 | 07:53 PM
Blindstuff's Avatar
My manifold is a piece of **** also, i dont think i can get 3" away from the block. I will take a pic soon, it sucks real bad, but since it get the job done and i got it for 50 bucks i wont say anything
Edit: This is only in until i get to boost and i know it runs ok, after that i will get a better one
Modified by Blindstuff at 12:05 AM 6/2/2004
Old Jun 1, 2004 | 10:40 PM
d_mina's Avatar
Default Re: EGT probe tap and information. (pb16b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b &raquo;</TD></TR><TR><TD CLASS="quote">usually you'd tap the egt probe onto the header close to the cylinder head. since you're running a turbo, it makes sense to tap it after the turbo on the downpipe somewhere. when you run lean, it will get hotter. rich will run cooler. </TD></TR></TABLE>
"Many people think that the leaner you go, the higher the EGT gets. This is also incorrect. Peak EGT occurs at stoichiometry- about 15 to 1 for our purposes. If you go richer than 15 to 1, EGT will drop and if you go leaner than 15 to 1 EGT will ALSO drop. It is VERY important to know which side of peak EGT you are on before making adjustments. It is safe to say that peak power will occur at an EGT somewhat colder than peak EGT." - https://honda-tech.com/zerothread?id=248965 - great post!
Old Jun 1, 2004 | 11:03 PM
ek9vboi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blindstuff &raquo;</TD></TR><TR><TD CLASS="quote">My manifold is a piece of **** also, i dont think i can get 3" away from the block. I will take a pic soon, it sucks real bad, but since it get the job done and i got it for 50 bucks i wont say anything
Modified by Blindstuff at 12:05 AM 6/2/2004</TD></TR></TABLE>
thats 1 ugly ****.
Old Jun 1, 2004 | 11:12 PM
ATS*Mark's Avatar
OG triple OG
Default Re: EGT probe tap and information. (b20boost)
the reason why they recomend you mount it after the turbo on turbo cars is , if the probe happends to break , it doesnt go through the turbo and destroy it .
Old Jun 2, 2004 | 02:12 AM
Blindstuff's Avatar
Default Re: EGT probe tap and information. (teameracer3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teameracer3 &raquo;</TD></TR><TR><TD CLASS="quote">
"Many people think that the leaner you go, the higher the EGT gets. This is also incorrect. Peak EGT occurs at stoichiometry- about 15 to 1 for our purposes. If you go richer than 15 to 1, EGT will drop and if you go leaner than 15 to 1 EGT will ALSO drop. It is VERY important to know which side of peak EGT you are on before making adjustments. It is safe to say that peak power will occur at an EGT somewhat colder than peak EGT." - https://honda-tech.com/zerothread?id=248965 - great post!</TD></TR></TABLE>
Thanx you so very much
So, in conclusion. What do i do??? #3 Runner or DP???
Old Jun 2, 2004 | 03:49 AM
JDMCRX's Avatar
Um were is the oil feed
Old Jun 2, 2004 | 06:53 AM
ATS*Mark's Avatar
OG triple OG
Default Re: EGT probe tap and information. (JDMCRX)
ahahh i just noticed that , is it capped off???????
Old Jun 2, 2004 | 07:47 AM
d_mina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blindstuff &raquo;</TD></TR><TR><TD CLASS="quote">Thanx you so very much
So, in conclusion. What do i do??? #3 Runner or DP???</TD></TR></TABLE>
HELLA_JDM's had a good point about the probe breaking pre-turbo...I guess it would be a smart idea to mount if after the turbo...mine is mounted on the downpipe
Old Jun 2, 2004 | 07:55 AM
MachAF's Avatar
It is a good idea to run both a wideband and and EGT.
Peak power will be 100 F rich of peak EGT.
I would tap it in the manifold because it will be accurate. After the manifold all your temperatures are going to be cooler.
So you would do damage before you noticed it.
Old Jun 2, 2004 | 07:58 AM
PM-Performance's Avatar
Default Re: EGT probe tap and information. (MachAF)
i used to have mine on cyl 3 like 2 inches or so off the head. since i got the new manifold i decided not to drill into it so i mounted it in the dp now , right off the turbo. the egts are prob like 200 degrees off or so
Old Jun 2, 2004 | 09:35 AM
Blindstuff's Avatar
Default Re: EGT probe tap and information. (Hella_JDM)
Ok, i guess it will be #3 runner than. If anyone can draw a dot or something on the pic where you would tap it it would be nice.
Thanx for the help all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">ahahh i just noticed that , is it capped off???????</TD></TR></TABLE>
The oil feed is on the side, further down from the "cap".
That what you see capped is because the turbo was water cooled in its original car.
Old Jun 2, 2004 | 09:51 AM
seen4ever's Avatar
http://www.imagestation.com/album/?id=4287642973
picture 10 is a close up of the way I tapped into my manifold on #3. We welded the bung from autometer so that we could just screw in the probe.
Pullig
Jul 21, 2014 10:15 PM
djnikko
Jul 7, 2004 07:16 AM
91LUDESI
Sep 10, 2001 11:04 PM
Crxlsturbo
Aug 5, 2001 01:05 PM
Pro-Lude
Jul 31, 2001 04:10 AM
