EGT to high?!?!?!
Old Oct 24, 2002 | 02:35 PM
  #26
ion_four's Avatar
Default Re: EGT to high?!?!?! (DSF)
* running lean (not leaner than 14:1 though because the temps should read cooler past stoich)
* running supa-dupa rich
* severly retarded timing
At any rate, I'd find out the cause asap
Actually, I believe that egt's are at their highest aroung stoichiometric and drop off on either side (lean and rich) so, there is no way to tell if an engine is running really rich or really lean, just by the egt's, but if you know it's not lean (ie. smells rich/black crap on muffler) and you have high egt's (and your timing is on) then you are running rich.
Here's a great link someone posted a while back:
http://www.sdsefi.com/techegt.htm
::EDIT:: Doh, didn't see this was already posted...nice location DSF
My question: Does anyone have some egt's from a N/A honda engine? Maybe even one that's close to stock?! That would be killer to know.
[Modified by ion_four, 11:37 PM 10/24/2002]
Old Oct 24, 2002 | 02:37 PM
  #27
ion_four's Avatar
Old Oct 24, 2002 | 03:10 PM
  #28
Double 06's Avatar
New User
Default Re: EGT to high?!?!?! (ion_four)
just get ride of the EGT and get a wideband sensor. Then you will know for sure.
Hybrid96EK
May 11, 2009 10:38 AM
2SLO
Oct 26, 2005 06:24 PM
TypeC
Aug 29, 2001 07:23 AM
