EF Intercooler help
Old Mar 10, 2015 | 05:48 AM
ThefirstPACT's Avatar
Default EF Intercooler help
So I have a Precision 650 right now and the thing is massive (relative to the room I have) and I really don't want to cut out my grill and have a cut out front bumper for the intercooler and charge pipes.
Anyone have a brand name one they are using that will sit behind the bumper (with some trimming of course)?
Old Mar 10, 2015 | 05:54 AM
turbohatch96y7's Avatar
Whats you hp goal?
Old Mar 10, 2015 | 05:56 AM
Default Re: EF Intercooler help
I am going to be running a Garrett 57 trim .60 (I believe that's what it is). So I will be happy with anything over 300.
Old Mar 10, 2015 | 06:43 AM
Heres mine
Made 400whp
Its a louvered fin 3" thick
If you have a cheap ebay intercooler and dont want to chop your crash support bar you need something like mine
Old Mar 10, 2015 | 08:56 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Uh, that's an EK haha.... he has an EF. Totally different space behind the bumper. There is WAY more height, width, AND depth on an EK.
It's been close to a decade since my last EF turbo build, but the main problem is getting the intercooler piping to the intercooler. You are limited to very sharp bends or a custom back door set up. Your best in my opinion is to just have a custom intercooler made and call it a day if you want to keep the outside looking stock. The crash bar is important, but can be properly modified if needed to still provide some type of safety.
Old Mar 10, 2015 | 09:27 AM
Originally Posted by OneBadTurboCRV
Uh, that's an EK haha.... he has an EF. Totally different space behind the bumper. There is WAY more height, width, AND depth on an EK. It's been close to a decade since my last EF turbo build, but the main problem is getting the intercooler piping to the intercooler. You are limited to very sharp bends or a custom back door set up. Your best in my opinion is to just have a custom intercooler made and call it a day if you want to keep the outside looking stock. The crash bar is important, but can be properly modified if needed to still provide some type of safety.
I didnt even notice ef in the title
Either way i was just referencing the fact that if you have a well made intercooler it doesnt need to be 24" tall.
Mine is short and thick.....
Old Mar 10, 2015 | 12:22 PM
wantboost's Avatar
Who is Mr Robot?
Old Mar 10, 2015 | 12:27 PM
DO IT ON ALL FOURS
You can get away with it if your flow and core are efficient.
Old Mar 10, 2015 | 07:07 PM
wantboost's Avatar
Who is Mr Robot?
That's the nice thing about vertical flow cores. Even the smallest cores flow well.
Granted with either style core the endtank design plays a big role in how efficient the core is about cooling and flow.
Old Mar 11, 2015 | 02:08 AM
liam821's Avatar
25 Year Member
That's what she said.
Old Mar 11, 2015 | 09:46 AM
And my thread became a ***** joke lol
Old Mar 11, 2015 | 03:44 PM
KevinEF7's Avatar
I had the same issue, ended up going with a 2.5" thick garrett intercooler this time around as to not have to hack my bumper at all, and I wanted to run prelude foglights. It is there medium core intercooler
I got mine from greg @ goautoworks, had him weld on some cast 90* aluminum bends on the end instead of straight pieces, it allows for very easy backdoor piping just between the frame rails, I think tip to tip the intercooler is 32" which fits with about 1/2" clearance on each side of the chassis. Greg assured me the intercooler was good north of 300whp, and Ive had no problem daily driving with this intercooler for 2 years now @ 20+ psi, IATS never surpass 120* on the hottest days
Old Mar 11, 2015 | 05:20 PM
bgdriver's Avatar
SRT4 intercoolers fit really well with just a little trimming to the radiator support.
Old Mar 11, 2015 | 05:43 PM
wantboost's Avatar
Who is Mr Robot?
Did you buy that core with endtanks on it already? And do you have proof that it's a Garrett? Those definitely are China endtanks abd that doesn't look like a Garrett core. Who'd you but it from? Just looking out for members.
Yea the SRT4 stock intercoolers work well. They are a Garrett core and IIRC stay efficient to around 350hp. They must fit well because I see a lot of EF owners using them
Old Mar 12, 2015 | 10:23 AM
Dark_Teg's Avatar
I had to do some serious chopping trimming to fit my 650HP intercooler and keep ground clearance.
Everyone I have seen that tried to go under the support bar had ground clearance issues.
Old Mar 16, 2015 | 08:17 AM
mynameis_jeff's Avatar
Do you happen to have a pic with the bumper on?
Old Mar 16, 2015 | 10:23 AM
Dark_Teg's Avatar
I later painted the mesh black.
Old Mar 16, 2015 | 11:15 AM
ESP.net's Avatar
Crx: 650hp Precision took some doing on the 90-91 crx bumper with the air dams cut and bit of trimming up front on the grille... I had an HF so the stock bumper bar was the thin one... Probably could of even gone as big as the 750 one...
Old Mar 18, 2015 | 03:28 PM
dlaub25's Avatar
Cant speak power limits but have you considered A2W? I have an A2W setup on my CRX. The heat exchanger is much thinner than a regular A2A intercooler. Was able to fit under the factory bumper with a little trimming. Sorry this is the only photo I could find.
image hosting site over 5mb
Old Mar 18, 2015 | 10:59 PM
wantboost's Avatar
Who is Mr Robot?
Air to water is always a viable solution for space limited applications as seen above
Old Mar 20, 2015 | 06:32 AM
So I did some measuring and I guess I have the 600hp intercooler. I am just going to "backdoor" one of the end tanks. I have a friend who can TIG weld, so I am going to grab some 1/8th aluminium and have him fab it up for me.
slowcivic e g
Jan 21, 2012 06:53 PM
shocker911
May 26, 2010 09:13 PM
Creator
Jan 26, 2008 04:30 PM
ef dino
Jun 15, 2007 04:33 AM
