Ect question.
Old Jul 30, 2015 | 03:12 AM
nfg177's Avatar
Default Ect question.
I'm running water cooler setup on a 30r. I get my cold side from the bottom of my radiator and then feed to hot side via the coolant block drain plug on the front of the block with a 6an fitting. Question is would I get false / cooler ect readings because of my location on the block??? I'm getting between 154 to 143 act via Hondata s300. Motor feels considerable hitter in the bay. Just looking for ideas. Thanks guys!!
Old Jul 30, 2015 | 06:00 AM
TheShodan's Avatar
Moderator
Default Re: Ect question.
No. If you're getting a false reading, its either the sensor itself or a calibration of the sensor from which I understand Hondata allows?
But a false reading from running water lines to the GT30R? No. You have it setup perfectly.
Old Jul 30, 2015 | 07:19 AM
Dark_Teg's Avatar
Hondata gets its reading from the sensor in the T-stat housing. You may get different reading from the coolant system in other areas. This is usually only the case till the car warms up. You get to a point where everything equalizes.
Old Jul 30, 2015 | 08:52 AM
turbohatch96y7's Avatar
No
Thats the fan switch
The ect is under the distributor on b motors
Old Jul 30, 2015 | 10:33 AM
Dark_Teg's Avatar
Originally Posted by turbohatch96y7
No
I had the location of the sensor confused in my head. My bad...
Old Jul 30, 2015 | 11:11 AM
LightningTeg's Avatar
Community Builder
Fan switch is Tstat, ECT sensor is under dizzy, coolant gauge for dash is under dizzy (1 wire)
Old Jul 30, 2015 | 02:59 PM
wantboost's Avatar
Who is Mr Robot?
The way you have it plumbed you aren't getting cold water from the radiator...
The front block plug is after the water pump so that side "pushes" the coolant while the the side before the water pump gets "pulled" if that makes any sense.
So what's happening is the turbocharger is being fed hot coolant first which then exits into the cold side of the radiator. This isn't a big deal because the water cooling is only there to keep the oil temperature inside of the bearing housing below 300F, anything over that is where the oil in the bearing housing starts to coke and can clog bearing passages inside the turbocharger. The additional heat absorbed by the coolant from the turbocharger is minimal and shouldn't cause any noticable increase in coolant temperatures unless you have an issues somewhere else in the system.
This time of year your coolant temps shouldn't be that low. Either you don't have a thermostat installed or like suggested above either the sensor is bad or Hondata doesn't have the sensor properly calibrated. Also do you know what temperature thermostat is in it? It could either be too cold meaning it starts to open well before the coolant reaches operational temperature making it almost impossible to get it up to temp unless you beat on the car. The thermostat could also be stuck open as well. Although I doubt that's what it is.
First step is to unplug the harness from the ect sensor and measure the resistance of the sensor when the engine is cold and then start the car, let the coolant temp stabilize, and measure it again. Then you can compare these values to what the service manual says for a properly functioning ect sensor. If that checks out fine then you need to see what the sensor calibration is in Hondata.
What sort of cooling setup do you have?
Full rad or half rad, stock or aftermarket?
If half rad and no AC is there a panel blocking the opening to force air through the radiator?
OEM radiator fan or aftermarket, pusher or puller?
Fan switch on/off temp in Hondata?
What coolant? Standard 50/50, distilled water/water wetter, straight distilled water, etc
New or old water pump?
Is thermostat installed, installed properly, working properly, proper opening temperature?
Is the system filled to capacity and thoroughly bled?
And so on.
Old Jul 30, 2015 | 05:07 PM
nfg177's Avatar
And so on.
I have a half core radator with 2600 cfm slim fan no shroud pull style. Have fan overridden to be always on. Running 2 Bottles of water wetter and distilled water. System is burped correctly, thermostat is a gated i believe it opens at 170 so obviously my ect readings are off.
Old Jul 30, 2015 | 06:47 PM
wantboost's Avatar
Who is Mr Robot?
Well running a fan that large constantly is more than likely your problem. It has the capacity to keep coolant temperatures below the opening point of the thermostat which can cause a huge problem.
Old Jul 30, 2015 | 07:47 PM
nfg177's Avatar
Yeah but if that's the case why is the thermostat still opening I'm pretty sure I'm getting false readings false numbers
Old Jul 31, 2015 | 03:04 AM
nfg177's Avatar
Ok this is weird explain some please. My turbo is off being rebuilt at the moment so I can't real get op temp reading of resistance on my ect sensor at the moment but I said what the hell and did cold. Does this seem right to anyone. Car is cold not started**
Why is Hondata showing my ect at 129 degrees cold. When it's 73 degrees outside?? The resistance was 2.11.
Old Jul 31, 2015 | 03:47 AM
Community Builder
Just curious what single slim fan runs 2600CFM?
Old Jul 31, 2015 | 02:32 PM
nfg177's Avatar
That's what is claimed could be bs
Old Jul 31, 2015 | 04:32 PM
nfg177's Avatar
So I went to make sure I have the right CFM on the fan I was wrong its 2000 not 2600
Sprockets
Jul 20, 2016 06:49 PM
daboy155
Aug 1, 2015 12:29 PM
TegraGSXR
May 29, 2010 11:37 AM
tencan
Dec 31, 2003 01:36 PM
Mr.Integra
Feb 27, 2003 01:05 AM
