EBC or MBC?
Old Dec 3, 2004 | 03:42 PM
  #26
Drew Peacock's Avatar
Default Re: EBC or MBC? (fafsa)
I have always used MBC's Turbosmarts bleed valve and there dual stage. They both would spike and then drop back yes it does cost you power and it definitely makes tuning harder seeing how the boost spikes are obviously coming where peak torque in generated, detonation problems can occur. Then you have the a 1-2 psi drop off which really does effect top end power. They are great for low boost, but not really good enough for anything over 12psi IMO. If its a serious setup go for a EBC
Old Dec 3, 2004 | 06:27 PM
  #27
fafsa's Avatar
Default Re: EBC or MBC? (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">I have always used MBC's Turbosmarts bleed valve and there dual stage. They both would spike and then drop back yes it does cost you power and it definitely makes tuning harder seeing how the boost spikes are obviously coming where peak torque in generated, detonation problems can occur. Then you have the a 1-2 psi drop off which really does effect top end power. They are great for low boost, but not really good enough for anything over 12psi IMO. If its a serious setup go for a EBC </TD></TR></TABLE>
that's what im worried about, i would consider this a "serious" set up and will be running more than 12psi. but ive also heard of turboxs and hallman holding high boost very well so i dont know
on the turboxs, is getting the dual stage even worth the extra 70/80?
Old Dec 3, 2004 | 07:42 PM
  #28
b18bEG's Avatar
fafsa you ahvea PM, if you didnt recieve it email me
cnelson81@gmail.com
Old Dec 3, 2004 | 07:51 PM
  #29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa &raquo;</TD></TR><TR><TD CLASS="quote">
on the turboxs, is getting the dual stage even worth the extra 70/80? </TD></TR></TABLE> In my experience they don't they are designed to spike up then drop off its better then boost creep.
Old Dec 3, 2004 | 09:06 PM
  #30
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote"> In my experience they don't they are designed to spike up then drop off its better then boost creep. </TD></TR></TABLE>
damn, that's 2 for and 2 against
another question, to the people that were running the turboxs, are yall running the standard unit or the high performance? are they that much different? its like a $20-30 difference. i plan on running 18-19psi at the most
Modified by fafsa at 10:26 PM 12/3/2004
Old Dec 3, 2004 | 11:27 PM
  #31
Quad-Damag's Avatar
my pref b spec 1, 1st gen with the ****, is fucken sick, HOLDs boost great, 12 psi, all the way till redline.
Old Dec 4, 2004 | 07:55 AM
  #32
PrettyLude's Avatar
that's probably one of the easiest boost controllers to use, along with my blitz sbc-id
Old Dec 4, 2004 | 08:05 AM
  #33
alpha's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote"> along with my blitz sbc-id</TD></TR></TABLE>
My favorite out of them all.
Old Dec 4, 2004 | 08:19 AM
  #34
.::Lee::.'s Avatar
Default Re: (0x64)
Cort Green (uglyasscivic) last time I checked was running the Turbo XS dual MBC and is making in the ballpark of 700 hp at 30 psi. Check with him for more details, but it sounds like they work just fine on high boost.
Old Dec 4, 2004 | 10:38 AM
  #35
fafsa's Avatar
Default Re: (Ibiza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza &raquo;</TD></TR><TR><TD CLASS="quote">Cort Green (uglyasscivic) last time I checked was running the Turbo XS dual MBC and is making in the ballpark of 700 hp at 30 psi. Check with him for more details, but it sounds like they work just fine on high boost.</TD></TR></TABLE>
was looking into that also, but does anyone have any truth to the turboxs standard unit and the high performance unit?
Old Dec 4, 2004 | 10:49 AM
  #36
.::Lee::.'s Avatar
Default Re: (fafsa)
Corts is not the hi-performance one, it's just the dual stage. I don't really know anything about the difference between the single stage ones.
Old Dec 4, 2004 | 12:46 PM
  #37
fafsa's Avatar
Default Re: (Ibiza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza &raquo;</TD></TR><TR><TD CLASS="quote">Corts is not the hi-performance one, it's just the dual stage. I don't really know anything about the difference between the single stage ones.</TD></TR></TABLE>
anyone expeirence both the standard turboxs and the high performance turboxs? i was looking into the high performance (since im gunna run 18-19psi) but its almost the same cost as the dual stage
Old Dec 4, 2004 | 02:42 PM
  #38
coupon's Avatar
Default Re: (fafsa)
anyone expeirence both the standard turboxs and the high performance turboxs? i was looking into the high performance (since im gunna run 18-19psi) but its almost the same cost as the dual stage </TD></TR></TABLE>
Old Dec 4, 2004 | 08:54 PM
  #39
fafsa's Avatar
Default Re: (slowredhybrid)
anyone?
Old Dec 4, 2004 | 11:41 PM
  #40
coupon's Avatar
Default Re: (fafsa)
up for some info
Old Dec 5, 2004 | 12:58 AM
  #41
alpha's Avatar
Another thing I like about EBC's is gear or speed dependence (especially tonight).
Old Dec 5, 2004 | 09:45 AM
  #42
coupon's Avatar
up, someone give me some insight b4 i buy
Old Dec 5, 2004 | 10:38 AM
  #43
fafsa's Avatar
Old Dec 5, 2004 | 02:10 PM
  #44
fafsa's Avatar
Default Re: (fafsa)
Old Dec 5, 2004 | 03:42 PM
  #45
coupon's Avatar
Default Re: (fafsa)
someone
Old Dec 5, 2004 | 03:44 PM
  #46
MooreBoost's Avatar
I think Im going to go for the Profec Spec I, but I'm not sure.
Old Dec 5, 2004 | 03:57 PM
  #47
fafsa's Avatar
Default Re: (tegunderpressure)
turboxs standard unit performance vs turboxs high performance? is it worth it 2 spend $30 more or will the standard unit hold high boost well too?
Old Dec 5, 2004 | 04:13 PM
  #48
MooreBoost's Avatar
Default Re: (fafsa)
It's just 30 bucks, may as well.
Old Dec 5, 2004 | 04:16 PM
  #49
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">It's just 30 bucks, may as well.</TD></TR></TABLE>
but then the dual stage is just 30 more from the high performance. anyone have any expeirence?
Old Dec 5, 2004 | 04:22 PM
  #50
MooreBoost's Avatar
Default Re: (fafsa)
But then the Greddy Profec-B is just another 45 more, then the Greddy Profec-B Spec II, is just another 35 more, then the Apexi AVC-R is just another 50 more.
Ketch my drift?
