Easy Coolant question. Already searched 8 pgs.
I recently had some work done to my car. I have a t67 turbo half civic rad. setup. Long story short there needed to be coolant added and all that was available was 50/50 Peak Antifreeze. I needed to add about 3/4 of the gallon. I had been using Prestone. Peak states it can be added with any coolant. Should I drain and put Prestone back in? Is a flush necessary? thanks for any help.
Re: Easy Coolant question. Already searched 8 pgs.
ok, that's what I thought, but wanted to be sure. i'm going to get the tuned this weekend and wanted everything to be good. Thanks
The only thing you wouldn't want to mix is the OEM blue stuff, and only because it would reduce it's anti-corrosion properties.
gotcha. It would be a long time before I bought something from oem from the Honda dealer where I live. the prices are outrageous!!!!
deefl44
Honda CR-V & Element
11
03-16-2015 11:47 AM
JoshuaVTEC
02-27-2005 03:12 AM
