Earls Fuel filter ok to use?
Old Jun 28, 2007 | 08:16 PM
LilCivic04's Avatar
Default Earls Fuel filter ok to use?
i was wondering if it is ok to use this fuel filter? It seems really small and i've seen some people on h-t use it also.
i got this picture from another members thread but if you want me to take it off let me know
Old Jun 28, 2007 | 08:18 PM
cltitus's Avatar
wouls just fine if you get the right noe
Old Jun 28, 2007 | 08:19 PM
LilCivic04's Avatar
Default Re: (cltitus)
i was thinking of this one " http://store.summitracing.com/...w=sku "
what are the cons of running this small of a filter?
Old Jun 29, 2007 | 08:17 AM
tony413's Avatar
its the micron numbers that count not the physical size
from tank to pump run 80-100 micron
after pump before rail run 10-60 micron
Old Jun 29, 2007 | 09:40 AM
sp00led's Avatar
Default Re: (tony413)
I've got a -4AN earl filter I got from summit. Works fine just had to get an adapter since I had -3AN oil lines. I heard there was somebody, maybe stan@fast-turbo.com that sells a -3an.
Old Jun 29, 2007 | 10:21 AM
LilCivic04's Avatar
Default Re: (sp00led)
what an size should i get? 3an line seems a bit small.
Old Jun 29, 2007 | 06:16 PM
LilCivic04's Avatar
Default Re: (LilCivic04)
Old Jun 29, 2007 | 06:25 PM
ej8's Avatar
ej8
-6an
Old Jun 29, 2007 | 07:11 PM
LilCivic04's Avatar
Default Re: Earls Fuel filter ok to use? (LilCivic04)
so is it ok to use it for daily driving?
Old Jun 30, 2007 | 09:22 AM
tony413's Avatar
yes like i said micron levels are important not really the physical size
Old Jun 30, 2007 | 09:46 AM
Boosted Chemist's Avatar
Default Re: Earls Fuel filter ok to use? (tony413)
I run a jegs -8an compact with no problems. ( Street car )
Old Jun 30, 2007 | 06:50 PM
LilCivic04's Avatar
Default Re: Earls Fuel filter ok to use? (Boosted Chemist)
how often does this filter need to be cleaned?
Old Jul 1, 2007 | 10:04 AM
tony413's Avatar
i havent seen any filter that you clean most of them are just exchangable cores
Old Jul 1, 2007 | 11:56 AM
nonvtecallmotor's Avatar
That filter is made for low psi. Its not meant for fuel injected setups.
Old Jul 1, 2007 | 12:39 PM
.RTErnie's Avatar
Default Re: (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">That filter is made for low psi. Its not meant for fuel injected setups.</TD></TR></TABLE>
the one pictures is for CARB APPS ONLY!!!!
if you go to http://www.anplumbing.com they have an EFI filter...its black and gold. I have one on my car. REALLY nice.
Old Jul 1, 2007 | 01:48 PM
It works fine, i installed it in my car and im hitting 15 lbs and my afrs are dead nuts. In fact after switching to this style setup, my afrs where kinda rich at low rpms and low load.
Old Aug 31, 2007 | 11:06 AM
Fuster_Cluck's Avatar
I'm going to grab one of the Earls filters. They are good up to 75psi. The K20a2 operates at 50-52psi. It will be fine not to forget there are numerous people running these filters with no problems
Old Aug 31, 2007 | 11:20 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Hybrid93Hatch)
you may want to look into a pleated filter. the one pictured can clog rather fast and need constant attention. a pleated filter has alot more surface area.
DarryCar
Mar 17, 2012 06:48 AM
EARLdaSQUIRREL
Feb 9, 2012 09:37 AM
iateshaggy
Apr 3, 2007 06:07 AM
ALMXDUPINTEGRA
May 17, 2005 03:06 PM
dustin
Aug 4, 2004 12:40 PM
