Eagle stroker kit....??
Old Apr 26, 2009 | 11:44 AM
h22_bb4's Avatar
Default Eagle stroker kit....??
hi
my brother gave me eagle stroker kit with srp pistons(low comp 8:1), the problem that he faces with the stroker is that when he assembled the engine the pistons came out from the block by around 1mm. the block was b16 block
so guys can you help me guys to solve this problem.
the crank has a number on it I dont know if it a part # or what...
the crank: b1633341890 also it has another number s-02-06-014
the rods have this stamped on them 5290HO
this is all what I got so if the pistons were stiking out of the block maybe I have to use b18 block because of the deck hight????? ( correct me if Im wrong)
I'm really confused and I dont know what to do....
any help will be appreciated
Old Apr 26, 2009 | 01:29 PM
grndcont's Avatar
Default Re: Eagle stroker kit....??
i would call eagle tomorrow and ask them what those part #'s were designed for.
Old Apr 26, 2009 | 01:44 PM
paulzy's Avatar
www.eaglerod.com
Old Apr 26, 2009 | 01:45 PM
non-VTEC's Avatar
sounds like the stoker kit was meant for a B18 like you said.....but call eagle up and find out for sure.
Old Apr 27, 2009 | 05:49 AM
h22_bb4's Avatar
thanx guys for the help
non-VTEC yea I was thinking that its a b18 stroker but when I see the part # on the crank it says b16 so this what made think that it's not a b18
I cheked the rods part # and its a b16 rods but about the crank I emailed eagle and Im waiting for their reply...
Old Apr 27, 2009 | 09:58 AM
2fastek's Avatar
with a stroker kit u have to get custom pistons, my homeboi just did this and had the same proplem. thsts y its always good to get the kit alltogher and not buy the crank and rods and off the shelf pistons seperately. The had to move the location of the piston pin so the piston sat at the deck.
Old Apr 27, 2009 | 12:38 PM
h22_bb4's Avatar
thanx for the input
what are the pistons specs????
thanx
Old Apr 27, 2009 | 02:41 PM
redflaredcrx90's Avatar
dude eagle cranks suck take it to a machine let them do it
Old Apr 29, 2009 | 10:29 AM
h22_bb4's Avatar
I did some research and found that...
1630311... are same as the stock b16 stroke 3.031
and the one I have is 1633341... are 3.335 stroke
so know I think that the b16 stock lenth rods well make the piston to stick out of the block (as I do now)
so I think that I have to use shorter rods and this is the problem because I dont know where to get them.. and what are the wright lenght of them..??
can anybody help me PLZ.....
Old Apr 30, 2009 | 01:32 AM
h22_bb4's Avatar
bump....
need help
Topdawgg
Oct 27, 2006 11:48 AM
weiRtech
Aug 24, 2006 11:00 AM
mkell
Honda S2000
Dec 12, 2004 10:06 AM
