Eagle Rods, where is the difference
Old Apr 21, 2004 | 11:59 AM
mrx's Avatar
mrx
Default Eagle Rods, where is the difference
Hallo,
can anyone tell me the difference between these two rods?
Eagle 900HP H-Beam Rods - B16
Eagle Extreme Duty H-Beam Rods - B16
What can handle more power? weight? which one should i use?
Searched allready but fond nothing.
Thanks
Malte.
Old Apr 21, 2004 | 12:12 PM
turbo*s2k's Avatar
Default Re: Eagle Rods, where is the difference (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">Hallo,
Thanks
Malte.</TD></TR></TABLE>
From what I found the "ESP" H beam rod will handle around 20 psi max. I'm not sure what the HP #'s are because people make different HP on the same PSI.
The "Extreme Duty" H beam rod I believe is the full race one. I'm going to call Eagle, and see what they say... I'll let you know.
Old Apr 21, 2004 | 12:32 PM
turbo*s2k's Avatar
Default Re: Eagle Rods, where is the difference (TurboChrgd_Civic)
I just spoke with Alan @ Eagle and he said that the
"ESP" rod depending on bolt size used can handle up to 650+hp. Now there using the ARP 3/8 2000 bolts so the rods can hold more. I think he said the old bolt used was a 5/16 bolt, but they can still hold quite a bit hp.
"Extreme Duty" rod will will handle over 1000+hp. This rod was developed for people that are looking to run more 1000 hp.
Anybody else have some in sight in to this...
Ak_ef9
Oct 2, 2006 06:53 PM
B16Civic93
May 8, 2005 07:41 PM
1point7T
Mar 30, 2004 06:56 AM
shingles
Nov 8, 2001 07:51 AM
