Need quick advice please!
Old Oct 25, 2003 | 08:56 PM
Hoosier Daddy's Avatar
Default Need quick advice please!
Hey guys I found JE pistons and Eagle rods for $450. Sounds like a great deal to me, but don't Eagle rods have an issue with the rod bolts backing out? Is there a way to fix this? Should I use other rod bolts? Any/all help would be very much appreciated. Should I jump on this? They've been used for 1,000 miles. He said he's decided to go with a different setup.
Thanks
Old Oct 25, 2003 | 09:20 PM
DaveF's Avatar
Default Re: Need quick advice please! (Boost Creep)
eagle rods are fine. IF you install them properly. you can upgrade the rod bolts on the eagle rods if you dont feel comfortable with them.
Old Oct 25, 2003 | 09:23 PM
Default Re: Need quick advice please! (2.2Lcivic)
Thank you sir. I was just reading another thread about this and there were mixed replies in there.
http://www.inlinefour.com/arpheavdutro.html
Would those be a worthwhile upgrade? Can I use those with no modification?
Old Oct 25, 2003 | 09:35 PM
B18C GSR CIVIC's Avatar
My mech makes 550whp in his daily driven civic and has stock eagle rods and bolts. I made close to 400whp with eagle bolts daily drivin.
We talked about the bolt upgrade but dont really need it unless you plan to rev above 9000 and making over 400whp daily driving!
good deal!
Old Oct 25, 2003 | 09:42 PM
Default Re: Need quick advice please! (B18C GSR CIVIC)
Feeling better about my purchase. I ended up buying them Looked absolutely mint in the pictures, hopefully they are. Now all I need is some new rings...they were only used for 1k miles but I don't want to take any chances.
I'm only going to be boosting 8psi on the streets and 10-12 at the track, so they should hold up. This is also in a LS motor, so I wont be revving high.
Old Oct 25, 2003 | 09:46 PM
Youll be fine man. Have no worries. Just make sure you get new main bearings and ****
happy boostin!
Old Oct 25, 2003 | 09:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C GSR CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">Youll be fine man. Have no worries. Just make sure you get new main bearings and ****
happy boostin!</TD></TR></TABLE>
Thanks man The block is going to be hot tanked and bored .20 over. It's also getting new gaskets/seals/bearings.
Should I replace the rod bearings as well or keep the ones they have? I was going to get the ACL bearing kit.
Old Oct 25, 2003 | 09:54 PM
Mine had all those things but I still stayed with stock oem bearings as did my mech. So I dont see a need to spend extra money if you dont have to. Just like the pro drive oil gears I had, BLAH, stock is just as good. STAY AWAY from unorthadox crank pulleys = death to engine
Old Oct 25, 2003 | 10:04 PM
Thanks for the advice I've also heard bad things about unorthodox pulleys.
Jun 12, 2008 05:35 PM
reaction360
Sep 22, 2007 05:52 PM
LSR-Abuser
Feb 26, 2006 05:10 PM
pimpintyperintegra
Nov 7, 2004 09:17 AM
JunIntegra
14
Oct 29, 2003 01:12 AM
