E85 vs 100oct?
Old Apr 24, 2009 | 06:58 AM
NirVTEC's Avatar
Default E85 vs 100oct?
Can some of you[that have researched/run] both tell me why someone in the midwest[where E85 stations are everywhere] would run 100oct in a 400whp Turbo car instead of E85?
100oct=$6/gal
E85=$2/gal
Old Apr 24, 2009 | 07:03 AM
kyden's Avatar
Default Re: E85 vs 100oct?
well e85 isn't always the same from station to station. so maybe for just consistency's sake?
Old Apr 24, 2009 | 07:08 AM
NirVTEC's Avatar
Interesting idea.....but considering 100oct(and other race fuels at stations) have been consistently proven to have lower octane than their rating because of sitting in the underground tanks longer than More Popular fuels. This is a reason I used to make my own Race Fuel with Toluene.
Thanks though!
NEXT?
Old Apr 24, 2009 | 09:27 AM
TheShodan's Avatar
Moderator
Because we don't all always want to run on race gas or E85 all the time. ROM rating for E85 is different than the actual 100 octane, which is why we don't use it in MI or OH much.
Old Apr 24, 2009 | 09:38 AM
gringotegra's Avatar
well i was used to put 5gal ($50) of 110oct race gas in my car every weekend for racing...not because i needed it but because i wanted it for safety reasons (boost spike ETC)..now i run on E85 and have been for the past 20k miles... its not only cheaper it makes more power... i dotn know what that guy is running race gas over E85... maybe he doesnt have the fuel system for it or something idk... maybe he likes the smell of 100oct .... i may not be getting as good of gas milage but i have gotten 28mpg on the highway with E85 (AFR's were high 17's )
Old Apr 24, 2009 | 10:45 AM
96 GSR-T's Avatar
Only reason I can think of is his fuel system is too small.
Old Apr 24, 2009 | 11:19 AM
E85B18's Avatar
Go with E85 if your injectors are big enough
Old Apr 24, 2009 | 11:48 AM
TheShodan's Avatar
Moderator
I guess also because many of us here have multiple cars, and rarely DD the high power stuff. When we race, we take the RACE car. When we don't, we drive something else. Extra cars and beaters are a buyers market in this state, and can be gotten cheaper than it is to tune and refit the HP cars we have now.
You're looking at it from a cost/gallon standpoint for daily driving. For many people here, that doesn't apply. Spending hundreds more in fuel system changes and tuning just to save a few bucks at the pump later just doesn't work in MI. We have too many 110+ octane stations at the pump here. Its like spending $500 to save $50. Not really worth it. Even with big fuel systems.
Not to mention if you leave town to an area that doesn't have E85, you're kinda stuck unless you can change your settings of your management system to go back to 93 octane, but who wants to have a laptop in the car all the time?
But, to each his own. enjoy and godspeed.
Old Apr 25, 2009 | 07:19 AM
NirVTEC's Avatar
What fuel system changes are you referring to? Just adding injectors that can cycle 30% more fuel? If its pre-purchase, it would just be changing the order on injector size(no biggie)
Take a look at an E85 station map for Chicagoland.......Its unreal!
Thanks for the input guys...
Old Apr 25, 2009 | 08:37 AM
SilverEk3dr's Avatar
If ur fuel system is good enough to make the hp that your looking for on E85, then switching back to gas should be no biggie.. Just need your tuner to street tune on gas. So you can switch back and forth.
Old Apr 25, 2009 | 05:40 PM
TheShodan's Avatar
Moderator
It's already done. Why work even more? I guess the $3/gal difference just doesn't matter for the cost it takes to transfer things over to run on corn.. Just not as convenient as perhaps other people in the midwest at E85 hubs.
Old Apr 25, 2009 | 05:47 PM
IceySC's Avatar
im new to the turbo world what all do you need to run e85? is it just bigger injectors?
Old Apr 25, 2009 | 08:07 PM
.CUBISH.'s Avatar
i picked up 60hp over 110oct on my stock gsr on boost.. went from 320hp to 380hp on 11 psi
Old Apr 26, 2009 | 04:17 AM
96 GSR-T's Avatar
And more fuel pump, typically you use an additional 30% more fuel that what you would use with Gasoline. So if you want to make 600hp on E85 you need a fuel system that would support 800hp using Gasoline and so on.
Old Apr 26, 2009 | 06:15 AM
NirVTEC's Avatar
By switching from 110 to 106-107 E85? Thats strange.....
Old Apr 26, 2009 | 09:32 AM
IceySC's Avatar
ok let me ask you this then and see if i have the right stuff or if i need something else .
i have a 255 fuel pump,aeromotive fuel pressure regulator,880 injectors, golden eagle fuel rail and im trying to make 450whp. do i need to change anything?
Old Apr 26, 2009 | 10:04 AM
Not really.. people forget to factor in the Cooling Factor E85 has...
i have seen plonty of C16 Vs E85 tunes where E85 makes a significent amount more... From what ive read but i dont know how accurate it is, E85 has an octane rating about 105-107 but its motor Octane is 115-116...
Old Apr 26, 2009 | 10:18 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
take this discussion to the E85 thread.
Old Apr 26, 2009 | 11:00 AM
MikeySpec's Avatar
We've had a great amount of luck around here on e85 with turbo'd street cars. 100 oct. out of the pump is old news.
Old Apr 27, 2009 | 10:17 AM
NirVTEC's Avatar
Going to pass this info on to a friend!.....Maybe he should be going to you guys!
Mr HYDE
Jun 24, 2007 11:24 AM
turbociv
Sep 23, 2005 06:23 AM
sloweredcivic
Feb 8, 2004 08:35 PM
QCKGSR
Apr 4, 2003 03:53 AM
td04civic
Sep 4, 2002 08:59 PM
