E85 and NO intercooler?
Old Sep 10, 2009 | 09:04 PM
harlen's Avatar
Default E85 and NO intercooler?
anybody running on e85 with no intercooler? overheating issues? hp #s?
thinking about doing this with a small turbo on a b18a, so wanted to get some info, thanks
Old Sep 10, 2009 | 09:44 PM
atec's Avatar
Default Re: E85 and NO intercooler?
Any reason you want to go without a IC setup? if you ride on the street I suggest you get a IC?
if you ride with a massive turbo and only 1/4 Mile with methanol you will get away without...
Old Sep 10, 2009 | 10:04 PM
gringotegra's Avatar
Local guy here ran E85 and Meth inj with no intercooler... it was on a DSM tho heres a vid:
http://www.youtube.com/watch?v=3oyj0WNISlM
and they also did this sand truck.. E85 and meth inj no IC:
http://www.youtube.com/watch?v=aQd_gkycZIU
Old Sep 10, 2009 | 11:28 PM
oodie's Avatar
^^ I dont think those vechicles would make it in a daily driven situation. Why not get a intercooler. Just get a ebay one better than nothing.
Old Sep 11, 2009 | 12:07 AM
atec's Avatar
gringotegra:
Dont give him the wrong idea, the meth injection will cool the charge air a LOT, he is also using a big turbo, and as u see he only run 1/4 mile at the time.
I said in the earlier posts that is possible..
I assume the "poster" have a DAILY driven car... were driving without a IC makes no sence other that heated charge air and possible knock or detonation...
Old Sep 11, 2009 | 07:19 AM
96 GSR-T's Avatar
You need an Intercooler with E85 its not Methanol, pretend the stuff is gas and plan accordingly.
Old Sep 11, 2009 | 07:38 AM
ralph11sec's Avatar
i wonder how the iat's are with no IC and with meth inj.
Old Sep 11, 2009 | 08:04 AM
atec's Avatar
The meth are cooling the charge air a LOT, I calculated the temp drop based on the amount of sprayed meth per second and air temp, but dont remember or have the sheet here now.
The thing is, yes meth injection will work as an air cooler, but meth also make aluminum corrode or infact eats the way through aluminum,steel componens will rust....
you have aluminum head, aluminum ports,and steel valves and velveseats.. I se a lot of maintenance if Daily driven, also a tank of meth is not going to last forever, what do you do when you are empty?
Buy a cheap IC instead, of go with a okey brand.... drop the illution of meth injection at the road, it is not worth the effort.....
Old Sep 11, 2009 | 09:08 PM
harlen's Avatar
has anybody with a honda tried this out and recorded some data?
i just want to see what will happen without an intercooler, since there will be no pressure variation throughout the piping. and i figured the e85 would help drop the iats down enough so that it wouldn't be dangerous with a small amount of boost.
Old Sep 11, 2009 | 10:06 PM
96 GSR-T's Avatar
As I stated E85 does not have the cooling properties of Methanol, it burns cooler than gas but its not going to chill the Intake Charge like running Meth or spraying it will..... nobody has done it because its widely known that it does not have the same properties of Methanol, a used Intercooler for a small hp app can be had for $200 or so.
My IAT's are high with a large intercooler and E85, and since I see you live in TX I wouldnt even think twice about not running an Intercooler.
PURP
Nov 6, 2009 01:56 PM
wernhersey
Sep 12, 2007 09:48 AM
EJ8 GSR-T
15
Jul 2, 2007 07:39 PM
RuskeR
Aug 7, 2004 10:36 AM
p3s7
May 4, 2004 05:36 PM
