Intercooler vs. non-intercooler....
Old Nov 4, 2009 | 08:27 AM
PURP's Avatar
Default Intercooler vs. non-intercooler....
Anyone ever A/B test their turbo setup with/without an intercooler?
I am going to have to do ALOT of modifications to put in an intercooler when I add the turbo, so I'm just wondering if its worth the trouble.
Of course I know that its an improvement, but just how much of an improvement?
Old Nov 4, 2009 | 08:31 AM
azandford's Avatar
Default Re: Intercooler vs. non-intercooler....
The guy i bought my car from did dyno runs with and without and there was about a 20hp increase with the intercooler on. Intercooler = Longevity...some kits such as greddy do not come with one but imo its necessary
Old Nov 4, 2009 | 08:39 AM
Archidictus's Avatar
Unceasing Measure
Pretty sure the piping and intercooler kits you can get now come pre-bent and made specifically so you don't have to do a lot of modifications to get them to fit right. At least the last ten or so I've done have been that way
Old Nov 4, 2009 | 08:59 AM
grumblemarc's Avatar
The Grumpiest
What kind of mods? That front bumper of that bodykit might be one of them.
Old Nov 4, 2009 | 09:05 AM
j.packsb's Avatar
wat kind of front end mods on a eg/ek wouldnt allow u to fit even a small fmic? u should be able to make it work unless u have a body kit. unless its a BYS front bumper then u deserve to be slow anyway..
The Grumpiest
Get a sidemounted IC.
Old Nov 4, 2009 | 09:17 AM
j.packsb's Avatar
^^^ or this... if your going to go through the trouble of boosting, get an intercooler. no point in not getting one. itl take more boost to make the same poswer without one. be efficient and get one
azandford's Avatar
^^^ x2 unless you got all kinds of stuff on the side 2
Old Nov 4, 2009 | 10:11 AM
93egSLEEPER's Avatar
lose the body kit and add an intercooler... or have less power. up to you
Old Nov 4, 2009 | 10:13 AM
alphalanos's Avatar
you should be able to fit a skinny intercooler. If not you just have to do whatever it takes to make it work. function>form. I wouldnt run any turbo setup without IC.
Old Nov 4, 2009 | 10:18 AM
PURP's Avatar
Hence the reason for my original question...
How MUCH power???
Old Nov 4, 2009 | 10:28 AM
ill bet its a good 20-30hp if its a decent setup
Old Nov 5, 2009 | 04:10 AM
PURP's Avatar
OK, but what kind of percentage numbers are we talking?
Not to be a stickler, but 20-30 off of 200 (10-15%) is CONSIDERABLY more relevant than 20-30 off of 600. (3-5%)...
Old Nov 5, 2009 | 06:12 AM
mattyfo0z's Avatar
Just get an intercooler, and take off those stupid HIDs that you probably have in halogen housings without a retrofit, in addition to horn mounts - are you using Hella horns, or something?
Old Nov 5, 2009 | 06:33 AM
PURP's Avatar
Actually, the HID's are in a proper TYC HID projector housing, and that has nothing to do with my question.... but please feel free to voice your presumptuous opinions on unrelated topics.
Old Nov 5, 2009 | 06:47 AM
infinitypro12's Avatar
If you don't want to actually run better forced induction use an intercooler. The is a reason they are used and aren't just for show, cooler air means better results.
Old Nov 5, 2009 | 07:28 AM
The Grumpiest
With a little fab you could probably get something like this working. I don't know what your setup is so this may/may not be adequate. I wouldn't run with out one.
Old Nov 5, 2009 | 09:36 AM
Unseen Racer's Avatar
post in the correct forum.
this belongs in the F/I forum.
thread has been reported to Mods
Old Nov 5, 2009 | 10:01 AM
Hill4589's Avatar
It's a hybrid thread so I don't see why you reported it..
Anyways just weigh your options, is that body kit worth keeping or would you like to make more hp but go back to oem?
Old Nov 5, 2009 | 10:02 AM
j.packsb's Avatar
who in the world would rather have a body kit and horns over an intercooler for their turbo??..
Old Nov 5, 2009 | 10:44 AM
JHP's Avatar
JHP
Its all going to depend on your set up. No one is going to know unless you dyno your car with the FMIC and dyno it without. I looked around a little bit and some volvos had optional intercoolers on their turbo cars. The difference between the ones with them and the ones without was about 15-20 horsepower. Hope that helps.
Old Nov 5, 2009 | 10:48 AM
PURP's Avatar
Thanks. It would be even more helpful if you could tell me the actual HP's of the two... If you know what I mean... 200/220? or 140/160? or 930/950?etc...
Old Nov 5, 2009 | 01:27 PM
SOHC_MShue's Avatar
There are way too many variables to give you an answer. For small amount of boost you can get by with without an intercooler I wouldn't even bother wasting the money to boost the car.
Old Nov 5, 2009 | 01:33 PM
Turbo-LS's Avatar
Runnign a non-intercooled setup is ok for about 7 psi of boost on an average sized turbo. boost = hot compressed air. Hot air = useless in an engine. if you start cranking the boost up the intake temps will get very high and kill power and make the engine extremely prone to detonation aka kaboom grenade your block.
stop being retarded about your body kit and some rewiring and put a damn intercooler on the car or dont boost it its that simple
its either that or invest in an air to water intercooler setup
Old Nov 5, 2009 | 02:47 PM
GT35R_EF's Avatar
Make mine whatever you want
^^THIS
You think you're getting the same answer on here for no reason??? LISTEN. No one here can tell the future, no one knows the % of power you will lose, it is strictly dependent to every setup. Let the body kit go, it's 2009. There is no "weighing" options, I'll do it all for you. The intercooler is going to benefit you far more than any body kit will. It really is that simple, I promise.
