E85 CRX Project
Old Jan 25, 2008 | 02:34 AM
mrchris1979's Avatar
Default E85 CRX Project
Finally got her done. My set-up was a bit laggy prior to the E85 tune and just switching over to E85 just improved everything. I really loved the much improved response of the turbo. Just does not seem as laggy anymore. Peak torque jumped way up and of course peak WHP. We could have made more power but I just decided to settle on this for now. Max boost of 13psi. Very conservative tune to keep it alive for a while. 331 tq by 5800rpm was something to get used to. Burning out at 3rd gear on an LS tranny from a 70mph roll is pretty intense. I'm hoping to get some MT tires on there very soon.
B18c1, stock GSR head, Supertech block guard, 81.5mm 9.8:1 CP Pistons, Eagle Rods, stock sleeves, ACL Bearings, Skunk2 Intake manifold, Boostwerks top mount, T3/T04e Garrett 57 trim, 3"DP/Exhaust, Hondata S300.
Thanks to TC's Performance for the tune and block rebuild. Laskey Racing for refreshing the cylinder head.
Click on pics to enlarge:
400whp, 331tq @13psi
Old Jan 25, 2008 | 02:45 AM
dc2____R's Avatar
Default Re: E85 CRX Project (mrchris1979)
nice very impressing numbers off a 57 trim
i wish Canada would supply e85 over here
Old Jan 25, 2008 | 03:19 AM
Ovrbst_T66's Avatar
Default Re: E85 CRX Project (dc2____R)
I think there is two e85 stations in all of Ontario." mrchris1979" What are your afr's tuned for under boost on e85?
Modified by Ovrbst_T66 at 7:28 PM 1/25/2008
Old Jan 25, 2008 | 03:43 AM
Master M's Avatar
Nice numbers! And a good looking enginie bay too.
Old Feb 6, 2008 | 04:30 PM
type Gendy's Avatar
Default Re: (Master M)
Sweet setup bro
I'm getting my lsvtec together for my crx and i'm contiplating going down the e85 road as well since i have a pump across the street from my house
Old Feb 6, 2008 | 04:44 PM
HondaCivicSiR1's Avatar
Default Re: (type Gendy)
any pics of the fuel set up like the lines and stuff?
Old Feb 6, 2008 | 08:52 PM
RC000E's Avatar
Default Re: (HondaCivicSiR1)
I really have to add to the comment on the quicker spool. I've been retuning my delsol on E85 (lsvtec/gt3071R) and I'm really amazed at how much more responsive it is. I'm seeing boost as low as 3100 rpm now! I'm really shocked at the noticeable power increase overall as well.
This is a really impressive fuel and I'm so damn glad I decided to switch.
Old Feb 7, 2008 | 12:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">any pics of the fuel set up like the lines and stuff?</TD></TR></TABLE>
All stock fuel lines, tank and filter. Only change is a Walbro 255lph fuel pump.
Old Feb 7, 2008 | 12:17 AM
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">I really have to add to the comment on the quicker spool. I've been retuning my delsol on E85 (lsvtec/gt3071R) and I'm really amazed at how much more responsive it is. I'm seeing boost as low as 3100 rpm now! I'm really shocked at the noticeable power increase overall as well.
This is a really impressive fuel and I'm so damn glad I decided to switch.</TD></TR></TABLE>
Do you have a dyno sheet of your set-up? I'm thinking about using a GT3071R.
Old Feb 7, 2008 | 12:57 AM
RC000E's Avatar
Default Re: (mrchris1979)
No, I don't have anything to post. The only dyno in my area moved away. I just found a mustang dyno close-by though that's kind of hidden. I'm only running 8psi at the moment. I wanted to be a little cautious tuning the E85, then I'll put my 1bar spring back in.
I've had your turbo in the past, but I love LOVE the 30r...especially on E85. Like with your setup...the lagginess is just GONE on e85.
WH0R3nEF9
Nov 3, 2005 05:09 PM
used2baracer
Jun 11, 2005 06:37 PM
Cractos
Feb 13, 2004 05:46 PM
oMek
Feb 2, 2004 09:25 PM
