e-manage interaction light suppose to constantly blink?
Old Mar 19, 2005 | 09:29 AM
mike93eh
Guest
Posts: n/a
Default e-manage interaction light suppose to constantly blink?
when i put the emanage in check mode by just turning the car on, the lights come on but none of them blink. but with my car running, the interactive light (laptop connected) not the active light but the interactive light constantly blinks. is it suppose to do this? i thought this light comes on when a laptop is connected.
Old Mar 19, 2005 | 12:50 PM
mike93eh
Guest
Posts: n/a
oh im the only person on here with e-manage...
Old Mar 19, 2005 | 02:21 PM
mike93eh
Guest
Posts: n/a
its real simple. if you are running e-manage, tell me if your interactive light constantly blinks when running.
Old Mar 19, 2005 | 02:23 PM
Tchleung's Avatar
my friend doesn't in his Ralliart... Whenever it flashed or anyhting. there was generlaly something wrong
Old Mar 19, 2005 | 02:43 PM
mike93eh
Guest
Posts: n/a
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Whenever it flashed or anyhting. there was generlaly something wrong</TD></TR></TABLE>
interactive or active led?
Old Mar 19, 2005 | 02:46 PM
Tchleung's Avatar
sry I don't really know Emanage. waht'st eh difference? I was referring to the lights on the sdie of teh actual blue emanage box. like 3 lights I think on the side
Old Mar 19, 2005 | 03:04 PM
mike93eh
Guest
Posts: n/a
2 lights on the side.
1st light - interactive - supposedly lights up when you hook the laptop to it.
2nd light - active light, it can flash to give you the error codes and can flash different colors telling you something i forget.
Old Mar 19, 2005 | 03:11 PM
Tchleung's Avatar
Oh oaky. in taht case the interactive light always stayed solid. laptop hooked up or not.
Old Mar 19, 2005 | 03:17 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Oh oaky. in taht case the interactive light always stayed solid. laptop hooked up or not.</TD></TR></TABLE>
always stayed solid sounds as bad as mine constantly blinking...
we need some e-manage gurus
Old Mar 19, 2005 | 03:24 PM
Tchleung's Avatar
haha yea. seems like not many ppl use emanage comapred to other managments..
Goodluck tho man
Old Mar 20, 2005 | 04:38 PM
mike93eh
Guest
Posts: n/a
anymore insight on this??
Old Mar 21, 2005 | 01:55 PM
mike93eh
Guest
Posts: n/a
bump
Old Mar 21, 2005 | 02:57 PM
tepid1's Avatar
Default Re: (mike93eh)
find the h-t member "The Shodan". He will know for sure. I promise.
Old Mar 21, 2005 | 03:21 PM
NinjaTurtles's Avatar
Default Re: e-manage interaction light suppose to constantly blink? (mike93eh)
It constantly blinks while the car should be running
Old Mar 21, 2005 | 04:28 PM
mike93eh
Guest
Posts: n/a
Default Re: e-manage interaction light suppose to constantly blink? (NinjaTurtles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinjaTurtles &raquo;</TD></TR><TR><TD CLASS="quote">It constantly blinks while the car should be running</TD></TR></TABLE>
but why would they make it so it constantly blinks doesnt make sense. its annoying me i guess i better put some tape over it hah.
Old Mar 21, 2005 | 04:31 PM
mike93eh
Guest
Posts: n/a
Default Re: (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">find the h-t member "The Shodan". He will know for sure. I promise.</TD></TR></TABLE>
is he a e-manage master? heh ill pm him thanks..
Old Mar 21, 2005 | 04:44 PM
JustinL's Avatar
mine kinda flashes like a cable modem in use. really fast jittery flashes not consistent with any pattern. i too was wondering what that was
Old Mar 21, 2005 | 05:48 PM
mike93eh
Guest
Posts: n/a
Default Re: (pyro_assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin &raquo;</TD></TR><TR><TD CLASS="quote">mine kinda flashes like a cable modem in use. really fast jittery flashes not consistent with any pattern. i too was wondering what that was</TD></TR></TABLE>
well hmmm, mine is consistent.
flash..flash..flash..flash..flash..
Old Mar 21, 2005 | 05:58 PM
''s Avatar
I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine.
Old Mar 21, 2005 | 06:44 PM
mike93eh
Guest
Posts: n/a
Default Re: (l337hxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l337hxr &raquo;</TD></TR><TR><TD CLASS="quote">I have emanage. And YES the "interaction" light does BLINK in a steady pulse. This is because i was told there is no connection to comuter, hence the USB port. Not 100% sure.
But the main thing is the active light, the GREEN light. When you give it gas, the Active LED should TURN green and when you let off gas it will go to orange. If the active light is doing what i am saying, then it is working fine. </TD></TR></TABLE>
alright i guess everything is okay then. thanks
i believe if youre below 1000rpms then its orange.
Old Mar 22, 2005 | 07:30 AM
Hyaboosta's Avatar
yeah my emenage interaction light blinks constant. When the active light starts to go red,yellow,green then you FvCKED.
Daryl Reyes
Jan 12, 2016 03:34 PM
Shintakun
Honda Civic (2001 - 2005)
Nov 5, 2008 11:25 PM
Type_R_Kills
Aug 31, 2006 02:39 PM
