Dynoed LS: Tuners Advice!! having problems.
Old Mar 31, 2004 | 01:05 AM
  #26
Retired's Avatar
WEST COAST
Default Re: Dynoed LS: Tuners Advice!! having problems. (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
no way, you need to have a solid 11.8-12.0 straight line regardless of pump or race.
you're afr line sucks, you want a straight line. </TD></TR></TABLE>
I must agree... clean up your air fuel and you will see power levels like this also at the high rpm advance the timing some more depending on the octane it will bring up the power band a little more . Also a little larger cam will help bring up the power curve as well. I say throw those stage 2 cams in thier but retard the intake cam a little... Good luck and Happy Boosting
Old Mar 31, 2004 | 05:06 AM
  #27
tony1's Avatar
Default Re: Dynoed LS: Tuners Advice!! having problems. (SPARK RACING INC.)
Maybe i missed it, but did you guys just throw in race gas and not change the map at all?
Old Mar 31, 2004 | 05:14 AM
  #28
Mr.DC2TurBo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPARK RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">
I must agree... clean up your air fuel and you will see power levels like this also at the high rpm advance the timing some more depending on the octane it will bring up the power band a little more . Also a little larger cam will help bring up the power curve as well. I say throw those stage 2 cams in thier but retard the intake cam a little... Good luck and Happy Boosting </TD></TR></TABLE>
wat's the setup on this graph and at wat psi?
Old Mar 31, 2004 | 05:28 AM
  #29
tony1's Avatar
Retard the intake cam???
Old Mar 31, 2004 | 06:03 AM
  #30
30psi Teg's Avatar
Default Re: Dynoed LS: Tuners Advice!! having problems. (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe i missed it, but did you guys just throw in race gas and not change the map at all?</TD></TR></TABLE>
No we had race fuel in the whole time. But we were concearned with the quality of what I came with so we got some from them. But then it ran worse. I think whoever said that hotter plugs may have been needed was right because the plugs looked pretty dark grey after the new gas was put in.
Engine is sound leakdown proved ~10% corss the board and compression was ~180 across the board
My haltech base timing is synced in and stays in sync with the motor as revs increase.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote"> but why didn't you up the boost if you were on race gas? It would have been nice to see a 25-30psi pull... and might have explained some things.</TD></TR></TABLE>
We did raise the boost on this gas to about 23 psi but that yielded the same HP as the previous gas on 18psi this was just the only map I printed as all had similar shape.
Maybe its the cams I am going home shortly to change these out, only problem is my damn Innovate Wideband ******* quit working on me so I dont know what I am gonna do about that
thanks for all the input
Old Mar 31, 2004 | 06:57 AM
  #31
Stewie's Avatar
Default Re: Dynoed LS: Tuners Advice!! having problems. (30psi Teg)
haha 10% leakdown is terrible if it's all past the rings.
Old Mar 31, 2004 | 07:57 AM
  #32
9SECQTR's Avatar
yea whats up with those #s i have a ls set up also and last year with the t3/t04e DRT in woodside queens, ny got 309 whp and i think 265wtq? it was somewhere between 255-265
Old Apr 1, 2004 | 06:05 AM
  #33
30psi Teg's Avatar
Default Re: (9SECQTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">haha 10% leakdown is terrible if it's all past the rings. </TD></TR></TABLE>
haha no its not and actually my gauge only goes down to 10% then just says set below that so like #2 was at ~9-10 and the rest were lower like around 4-5% and since cyl 2 got scratched pretty bad when my motor let go and I just honed it b/c I didnt want to step up to a 84mm bore I would say that is fine I just didnt feel like writing all this. So sorry on my part for not specifying
Modified by 30psi Teg at 7:42 AM 4/1/2004
Old Apr 1, 2004 | 12:06 PM
  #34
Kwuaymaikrup's Avatar
Default Re: (30psi Teg)
I for one KNOW that bad leakdown #'s will yield NO power. I would definatelly check that out if it is pulling 10%. That could be a major source of your problems. Good luck.
-Ryan
Old Apr 2, 2004 | 05:00 AM
  #35
tony1's Avatar
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">I for one KNOW that bad leakdown #'s will yield NO power. I would definatelly check that out if it is pulling 10%. That could be a major source of your problems. Good luck.
-Ryan</TD></TR></TABLE>
You're kidding right? 10% leakdown on a turbo motor will hardly change power at all. We've run 8's with 60-80% leakdown all across the board from bad valve seats.
Old Apr 5, 2004 | 07:14 AM
  #36
30psi Teg's Avatar
Default Re: (tony1)
You're kidding right? 10% leakdown on a turbo motor will hardly change power at all. We've run 8's with 60-80% leakdown all across the board from bad valve seats. </TD></TR></TABLE>
Thank You, I am also confident that leakage is playing a role in any of this.
For now I am going to go with the cams and tuning that are being my problem. So I am out right now with a broken diff but hopefully be able to get back soon for some tuning.
Hey tony1 just off hand how much power could someone actually stand to gain off of a good tune.
Old Apr 5, 2004 | 03:35 PM
  #37
Cyphear's Avatar
I know you didn't ask me, but i'd say you stand to gain as much as 50whp from a good tune.
Old Apr 5, 2004 | 05:45 PM
  #38
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">Hey tony1 just off hand how much power could someone actually stand to gain off of a good tune.</TD></TR></TABLE>
Well, depends how far off you are to begin with. A "good" tune doesn't always yeild the most power. Alot of people seem to forget that. A "good" tune is one that makes good power, gets good gas milage, runs smooth at all times, and is RELIABLE! I see alot of cars that make good power, but what you don't hear about is when the blow up from too much timing or being too lean. So, there's no way to really say how much is to be gained for a good tune without seeing your car and your maps.
Old Apr 5, 2004 | 05:52 PM
  #39
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (tony1)
Well, depends how far off you are to begin with. A "good" tune doesn't always yeild the most power. Alot of people seem to forget that. A "good" tune is one that makes good power, gets good gas milage, runs smooth at all times, and is RELIABLE! I see alot of cars that make good power, but what you don't hear about is when the blow up from too much timing or being too lean. So, there's no way to really say how much is to be gained for a good tune without seeing your car and your maps.</TD></TR></TABLE>
Please listen to him...I learned my lesson Twice.
Old Apr 5, 2004 | 05:57 PM
  #40
Stewie's Avatar
Default Re: (tony1)
ya but, are you using leaded fuel?
Old Apr 5, 2004 | 06:21 PM
  #41
tony1's Avatar
Default Re: (Mac8008)
Maybe i'm missing something, but what does leaded fuel have to do with anything?
Old Apr 5, 2004 | 06:26 PM
  #42
ahobbs's Avatar
HELLO,GOOD MORNIN'
ya but, are you using leaded fuel?</TD></TR></TABLE>
You have just been owned.........They sell leading in Mexico. If you want some go there. Or go get Jet fuel.
Old Apr 5, 2004 | 06:33 PM
  #43
B18bEK's Avatar
Default Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
You have just been owned.........They sell leading in Mexico. If you want some go there. Or go get Jet fuel.</TD></TR></TABLE>
i don't understand how he got owned?
Old Apr 5, 2004 | 06:37 PM
  #44
espanol's Avatar
Default Re: (B18bEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">
i don't understand how he got owned? </TD></TR></TABLE>
maybe hybrid ls-t is having flashbacks..??
Old Apr 5, 2004 | 06:38 PM
  #45
B18bEK's Avatar
Default Re: (espanol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
maybe hybrid ls-t is having flashbacks..??</TD></TR></TABLE>
or hot flashes
Old Apr 5, 2004 | 06:54 PM
  #46
Mase's Avatar
antwaine are you pregnant AGAIN?
Old Apr 5, 2004 | 07:06 PM
  #47
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">antwaine are you pregnant AGAIN?</TD></TR></TABLE>
How did you know!.....I think i was owned actually. I never thought about race gas being leaded. never really heard anyone say it that way. I just thought about mexico having unleaded gas . I need the H-T hammer we used to have long tims ago for myself.....Sorry. dude
Old Apr 5, 2004 | 07:11 PM
  #48
6thgenaccord1's Avatar
How did you know!.....I think i was owned actually. I never thought about race gas being leaded. never really heard anyone say it that way. I just thought about mexico having unleaded gas . I need the H-T hammer we used to have long tims ago for myself.....Sorry. dude</TD></TR></TABLE>
Hahahaha
Old Apr 5, 2004 | 07:13 PM
  #49
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (6thgenaccord1)
race gas still has nothing to do with leakdown
Old Apr 5, 2004 | 07:20 PM
  #50
B18bEK's Avatar
this one
