Dyno and throwing map sensor code
Old Aug 19, 2003 | 01:12 PM
SDT Project EF's Avatar
Default Dyno and throwing map sensor code
Today i went to Dyno Spot racing to have my car (89 civic d16z6 turbo) dyno tuned. Best pull was 162.7hp 149.2 tq made with homemade turbo set up with tdo5-14b turbo. Problem is in all the pulls at about 5500rpm car throws code for map sensor power drops off . Iam using a V-afc to tune the fuel. To try and fix this problem at the dyno place had them install a check valve. Dynoed no check engine light but power was like 122hp. Installed 2 more check valves to see if it would help , no check engine light but still low 130hp. So took the check valves off and dynoed and got around 155hp but now getting check engine light for map sensor again. Any suggestions or ideas on how to get the car to stop throwing map sensor code. its obdo using d16a6 ecu. would converting to obd1 help . ANy help is appreciated thanks
Old Aug 19, 2003 | 08:17 PM
Default Re: Dyno and throwing map sensor code (SDT Project EF)
ttt
Old Aug 19, 2003 | 08:23 PM
Daniel's Avatar
Why not use a missing link instead of check valves. It's supposed to be a lot better than check valves.
Old Aug 19, 2003 | 08:26 PM
simple4012's Avatar
New User
Default Re: Dyno and throwing map sensor code (Daniel)
why not spend a lil more money and do the vafc hack. get some used dsm's and do that. search for vafc hack
Old Aug 19, 2003 | 11:22 PM
Default Re: Dyno and throwing map sensor code (simple4012)
i am using the v-afc hack and i have dsm 450's , but thanks for the suggestions. Anyone dyno with a missing link?
Old Aug 19, 2003 | 11:25 PM
Sinner's Avatar
my map sensor goes off when I run bloody rich. it happens to me a few times.
Old Aug 19, 2003 | 11:28 PM
project dc2's Avatar
jeeez CJ at least be more complete with the set up
CAR-89 civic si
motor- D16Z6
management-
PM6 ecu, stock 89 civic si ecu
DSM 450's
Apexi Vafc
turbo seet up
STD manifold, adaptere plate
14B turbo
3inch downpipe and exhaust , no cats
2 inchh chargee ppes,
starion intercooler
ACT clutch.
and CJ, put up your fuel settings !!!!!!!!!
Old Aug 20, 2003 | 12:40 AM
Default Re: Dyno and throwing map sensor code (project dc2)
Thanks Phil "Turbo FAB master"
fuel settings-Wide starting at 1,000rpm going to 8,000rpm 35% 48% 44% 40% 46% 50% 50% 50% Low is 30% 40% 40% 40% 45% 50% 50% 50%
vtec engages at 4800rpm
Old Aug 20, 2003 | 07:18 AM
TravSi's Avatar
why are u using check valves with the afc hack???? the afc hack takes away the use of those silly little things called check valves......
Old Aug 20, 2003 | 07:25 AM
Default Re: Dyno and throwing map sensor code (RexSiT3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexSiT3 &raquo;</TD></TR><TR><TD CLASS="quote">why are u using check valves with the afc hack???? the afc hack takes away the use of those silly little things called check valves......</TD></TR></TABLE>
;cars wieerd. itt likes to throw a map sensor code and go intto major limp mode. thats why we tried out somoe check valves.
Old Aug 20, 2003 | 07:54 AM
VTC_CiViC's Avatar
You're running -50% on the AFC when it throws a code?? How much boost are you running?
Old Aug 20, 2003 | 11:32 AM
Default Re: Dyno and throwing map sensor code (VTC_CiViC)
8psi
Old Aug 20, 2003 | 11:40 AM
psileepR's Avatar
New User
maybe an old and tired map sensor? you said obd0?
Old Aug 20, 2003 | 12:36 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SDT Project EF &raquo;</TD></TR><TR><TD CLASS="quote">8psi
That doesnt make any sense. The MAP voltage reduced -50% on the AFC should clear 8psi with no problem. I guess your car is like my GSR... doesn't like the hack
Old Aug 20, 2003 | 12:50 PM
thanks for the advice and help. oh and how did you get around this problem with your gsr?
Old Aug 20, 2003 | 11:31 PM
thanks and ttt
Old Aug 21, 2003 | 04:21 AM
turb's Avatar
how bout swapping a fresh MAP sensor? maybe your map sensor is about to die..
Old Aug 21, 2003 | 08:43 PM
Default Re: Dyno and throwing map sensor code (turb)
Ok today i switched maps sensors with my brother. He has a 1993 integra ls. The sensor was a little bit different but looked just about the same. I drove the car and for like 3 or 4 pass shifting through grears letting it rev to like 6,500 no check engine light like it used to when it hit 5,500. Then i let my friend drive it and i rode with him. He pushed the car a little harder shifting at 7,000rpm and the check engine light comes on first for vehicle speed sensor then a little bit later for the map sensor. What could be the problem now?
Old Aug 22, 2003 | 07:27 AM
ttt heheheh im just too hardcore when i drive and throw codes
Old Aug 22, 2003 | 08:59 AM
VTC_CiViC's Avatar
So the new MAP sensor allowed you to see more boost w/o a CEL?
Old Aug 22, 2003 | 02:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">So the new MAP sensor allowed you to see more boost w/o a CEL?</TD></TR></TABLE>
I guess?
Shoalin R
May 21, 2010 01:42 PM
SDT Project EF
Aug 12, 2003 05:43 PM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
mracura
May 26, 2002 11:10 PM
BeanRacer
Nov 24, 2001 11:15 AM
